Winter tire fitment?
2023 ES300 h, tire size 215/55/17. Got a chance for a great deal for winter tires, just wondering if the slight size difference would be a no go. Winter size would be 225/55/17. Should I not?
Here are a few points to consider:
Originally Posted by Detailnut
(Post 11562353)
https://cimg2.ibsrv.net/gimg/www.clu...7a68fcf403.png https://cimg8.ibsrv.net/gimg/www.clu...47718af8d6.png |
225/55/17 would work fine. They would be both wider and taller than 215/55/17, but the difference is negligible. A wider tire is also worse in the snow, but again, only 10mm wider would make a negligible difference.
Tiresize.com provides a good visual comparison. You probably wouldn't notice much.
https://cimg4.ibsrv.net/gimg/www.clu...04b43dfa13.jpg |
225's will be fine. I have 215/55R17 on mine and the odometer is out slightly compared to the stock 18" tire size. So you'd see just a slight discrepancy of speed/mileage.
Originally Posted by LS500Fan
(Post 11563290)
I was just thinking about this today. I would seriously consider Michelin CrossClimate II. A European site did elaborately documented testing in wintry conditions and found they actually handled better in the snow than Blizzaks; the only area they really fell short was on ice. I'm very impressed and may make them my next set of year-round tires.
Originally Posted by Denzlex
(Post 11563340)
Your speedometer should read exactly the same with either 215/55/17 or 235/45/18, as the they are interchangeable. 215/55/17 is the factory size for the 17” wheel on the base ES. Both tires have identical overall diameter and revolutions per mile.
This is a copy and paste from my order Michelin X-Ice North 4 Studded Tires 215/55R17XL 98T Item #14047 Aha.... maybe it's because my tires are studded!!! |
(Post 11563453)
Yeah it was supposed to but it doesn't. I chalk it up to manufacturing tolerances, I don't care enough to literally measure the circumference.
(Post 11563479)
Studs wouldn’t make a difference. They barely protrude (about 1/32 of an inch). 215/55/17 and 235/45/18 are identical as far as the speedometer is concerned. Just curious, what makes you think your speedometer is off with the 17’s?
(Post 11563505)
I have checked the speed against GPS on a radar detector and a roadside side.
| All times are GMT -7. The time now is 11:27 AM. |
