Learn about your ES Hybrid Engine - A25 Dynamic Force reading page
For reference, the engine in our hybrid models is the A25A-FXS. The "FKS" is the non-hybrid variant, such as ES250 AWD.
https://toyota-club.net/files/faq/18..._df_r4_eng.htm
1) The 450h powertrain is an older-generation design
2) Weight/Performance. The 450h powertrain being a V6 is more geared towards the performance side of things. So naturally being a V6 and being more capable, it will just eat more fuel.
So I think it depends on the design goals for the particular application (frugal hybrid vs performance hybrid) and the generation of hybrid technology being used at the time. I'll bet the next RX will use a more advanced V6 hybrid system (LC500 system maybe?) assuming it does not use the NX system.
Now that I think about it how does the LC500 system compare to the 450h? Is it a new generation V6 hybrid tech? I haven't bothered to look.
While Atkinson came up with the idea of different "lengths" for the compression and power portions of the engine cycle for increased energy efficiency, his late 1800s implementation were mechanically complicated.
On the other hand, Miller came up with the idea of changing the effective length while keeping the same, relatively simple, mechanical length of the compression portion of the cycle by merely permanently changing the intake valve timing albeit at the reduction of output power (due to the reduction in air mass available for fuel combustion) from what would be produced from a non-altered valve timed Otto cycle engine of the same size. Unsatisfied with the smaller power output, Miller then worked on means of increasing the compressed air mass available for combustion to increase output power by means of superchargers or turbochargers; however, from a purist standpoint, the Miller cycle doesn't require either of those add ons - just the altered intake valve timing to change the ratio between the effective lengths of the compression and power cycle portions.
What name to use for what Toyota has implemented is, I think, one of those things you can argue about until the heat death of the universe without any final resolution. If one wanted to stir up the argument pot I'd throw in the name of the person who came up with the whole design/idea of combining Atkinson, Miller, and variable valve timing into Toyota's present day implementation.
From a practical standpoint, Toyota calls their implementation Atkinson cycle so to avoid confusion in general discussions it is best to go with the name Toyota uses.
