Heads up Display
Haven't tried it with head up display, but I've always had good results with Invisible Glass, a spray cleaner available at auto parts stores. The issue with using regular Windex-type cleaners is that sunlight makes the interior plastics "off-gas" molecules that cling to the glass. You need a solvent-type cleaner to remove them; household glass cleaners just smear them around.
Shame I can't just take it out of my car and hand it to you. I used it once, the night I picked up my car, then turned it off for the last 3 years... I find it very distracting at night.
Agree with Lee, probably very expensive to install in a non HUD car... Regarding the "B" pillars, just read an article that WD-40 cleans and protects the black painted finish.
That said; starting with the 2022 model year (provided you can live with your vehicle forever branded as a mere Luxury model and not the more prestigious Ultra Luxury model) you can plus up a Luxury model with options and add-on packages to obtain [with one exception] the same feature set in a Luxury model as you would get in an Ultra Luxury model minus the HUD. (The one exception you can't get on a Luxury model is the manual rear door sunshades.) Granted that wasn't possible in previous model years but that is no longer true now.
For more details on the 2022 Luxury versus Ultra Luxury feature set offerings see post number 19 in the "I have to ask the bad question." thread on this forum.
With the 2022 Ultra Luxury the HUD is standard equipment which most likely means no custom ordering avenue of not getting a HUD on an Ultra Luxury.
On a standard analog speedometer, like the ones I have on my 2006 IS250 and my 2001 Ford Ranger, I have real (not digital) needles pointing to printed MPH numbers, 10, 20, 30, 40 & so on.
The position of these real needles is a quick shorthand of how my speed is varying, except when using cruise control.
If the F-Sport had the option of an analog speedometer, even with the digital needle pointing to digital numbers, I would be happy not using the HUD.
Again, it's easier for me to read the digital speed numbers on my HUD rather than looking for them amid the clutter of the digital display.
This might be worth looking at. It replaces the driver's side speaker cover for HUD. https://www.aliexpress.com/item/1005002070347368.html
The 2022 base models ( 250 AWD, 350 & 300h) do not have performance dampers; all the other Luxury, Ultra Luxury, and F Sport model versions have them. (If I'm remembering correctly, I think 2022 is the first year for Luxury models to have performance dampers.)
