Android Auto Update For 2019 ES
For example for the CarlinKit T-Box there's also a CarlinKit T-Box Mini. If you compare the specs of the Qualcomm SOC (System on a Chip) used in each Qualcomm SDM450 Snapdragon 450 vs Qualcomm QCM2290 you should see that the execution characteristics of your predominate software usage cases will greatly determine which SOC will perform better. Although the full T-Box SDM450 based system has more RAM, eMMC flash, CPU cores, and software multithread support, the T-Box mini QCM2290 based system with the SOC's vastly greater performance GPU and builtin hardware support for H.264 video encoding for driving the Apple CarPlay H.264 video feed on the surface appears to be the better SOC for the general usage case. (You really need performance testing with the hardware and software to know for sure which will be the better system.)
For example, the T-Box Mini - Carlinkit Android 11.0 AI Box has this usage tip:
You will get the best experience if your screen supports the touch screen function. For cars that are not touch screens, it will be better if you buy an extra Bluetooth mouse for connection, or its compatibility is not as high as that of touch screen cars.
I don't think device specs alone will give you enough insight as to real world performance. For that I think you'll need a deep dive review with detailed evaluations of specific application usage scenarios covering the usage cases of your anticipated usage (e.g., map navigation, video playing, game playing, etc..).
I was asking for the specs on AA CarPlay in order to compare to similar devices. Not having any specs doesn't help. For all I know, my iphone 3GS is faster.
Navigation with the touchpad is a bit tricky, at some points, the only way to navigate with the touchpad is up and down.
I bought the "OTTOCAST Wireless Android Auto Car Adapter U2-X Pro" based on a recommendation from someone in another thread. This device gets about 75% of the Android Auto functionality in the 2019 ES350.
https://www.amazon.com/gp/product/B0BJPKY32N
. On a side note at least from my Car with ML I can tell a Big difference in Audio quality it seems your not getting full HD codec via the bluetooth / wifi onboard chip processing of this unit.
Thanks for the suggestion. Unfortunately it does not work fully for me I get in one time it works then another time please "retry by unplugging and replugging adapter" and it's also too slow to boot for me
Hey guys reviving this thread to see if there are any new recommended AA plug ins. I am just looking for something simple, no setup and definitely no custom installs. From what I have read on this thread and others many people have tried ottocast with a mixed bag of reviews.
I am using https://www.aawireless.io/en (AAWireless 2, new device that was recently released) .
Works perfect, without any issues (from day 1 since i got the vehicle, about 2 months now).
They have awesome support as well, they are regularly updating firmware's etc, i would highly recommend this.
Also, unit is so small that can fit anywhere (i can take a picture of my setup, if you would like).
I'm waiting for the AA Wireless TWO+ which should come out very soon and should have the wireless AA -> wired Carplay functionality we're looking for.
If you need CarPlay (Apple) i would recommend waiting for AAWireles Two+ , if not, no need to spend extra $.
Hardware wise i don't expect to see any difference (probably software only).
As none of the drivers (our household) using Apple devices, AAWirlees Two is perfect device.
