Silence Warning Beeps
Old May 12, 2026 | 04:10 AM
edbro's Avatar
edbro
Default Silence Warning Beeps
Yesterday I hauled some large boxes in the trunk and had to tie the trunk lid down as I couldn't close it. The entire ride home I had the flashing warning light and annoying beeper. Luckily, I only had to go two miles. Is there a way to silence the warning? Surely, I'm not the only person who had to tie down the trunk lid while transporting large objects.
Old May 13, 2026 | 12:19 AM
ESh's Avatar
ESh
Yes, you can close the latch of the trunk with a screwdriver.
Old May 13, 2026 | 08:23 AM
tfischer's Avatar
tfischer
25 Year Member
That's probably the best way to cut off the beeping for a short time. I've tried to silence several beeps in several Lexus cars, and it's pretty hard (although the RX speaker wire on the hatch can be unplugged, as I recall). Fabricating a device to push the switch into thinking the trunk is closed should work. If the screwdriver seems a little on the brute force side, and if you see a need to do this from time to time in the future, it would probably be worth your while to fashion a piece of wood or plastic (or pvc pipe) to insert and remove quickly. Maybe somebody can use one of those 3-D printer things to produce something that would do this. Maybe others here would be glad to buy it to keep in the trunk.
I'll take a look at the latch when I get to my car and see if inspiration strikes.
F_Throttle
IS F (2008-2014)
Jan 24, 2015 02:54 PM
Och
Apr 21, 2012 01:05 PM
DrGP
Jun 12, 2008 07:23 PM
305Cane
Jan 31, 2007 10:13 PM
