ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Steering Wheel memory personalized settings 2013
Old 03-13-18, 06:39 PM
gamma742
gamma742's Avatar
Default Steering Wheel memory personalized settings 2013
I don't like when hit the power button and the steering wheel moves. I figured out how to disable the seat from moving. Is it possible to disable the steering wheel too?
Old 03-13-18, 06:44 PM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
It is one of the personalized settings in the "dealer only" category. If you don't want to pay the dealer to change it, you can buy a Bluetooth OBDII connector and buy a Carista subscription, which will allow you to change that setting and other "dealer only" settings yourself.
Old 03-14-18, 09:59 AM
gamma742
gamma742's Avatar
Got it Les.. Thanks!
Autoaway/Return function.
While I was in there I turned on Windows and Sunroof Open with a Long Press "Unlock" of the FOB and disabled the Seatbelt Buzzer for Driver and Front Passenger.
xBROKER (03-16-18)
Old 03-14-18, 10:28 AM
mcomer
mcomer's Avatar
If your ES has Navigation and you went to Menu/Setup/Vehicle Customization/Other
your choices were Full/Partial/None. Full is wheel and seat, Partial is just wheel and
None is...well...none.
Old 03-14-18, 12:54 PM
gamma742
gamma742's Avatar
Yes I do have Navigation but that wasn't the case for me. I did try Partial and that changed the seat from moving back fully when it was set to Full. Then I changed to to None and the seat stops moving all together. All of the settings available Full/Partial/None had no bearing on the Steering Wheel.
Old 03-14-18, 12:57 PM
gamma742
gamma742's Avatar
To summarize; Full the seat moves a lot, Partial the seat moves but not as much, None the seat stays in it's position (no movement at all).
Old 03-15-18, 10:31 AM
lesz
lesz's Avatar
That is not the way it works with my 2017 ES. With the "partial" setting, both the steering wheel and seat still move, but the seat just does not move as far as with the "full" setting. None of the setting options seem to have any effect on the steering wheel movement. I just double checked it this morning to confirm that that is the case.
That is how mine works, too.
Old 03-15-18, 06:46 PM
gamma742
gamma742's Avatar
The good news is,, I was able to stop the steering wheel movement with Techstream at no cost.
Old 03-15-18, 08:20 PM
gamma742
gamma742's Avatar
Yes but you need a cable to connect to the OBD2 Port. Use your favorite search engine, an internet search will get you where you need to go.
xBROKER (03-16-18)
Old 03-16-18, 08:44 AM
jollick
jollick's Avatar
Originally Posted by XBROKER
What is a good source for techstream? It's just a program for a laptop?
You may be able to use Carista and their OBD II adapter. https://caristaapp.com/
Old 03-16-18, 10:06 AM
gamma742
gamma742's Avatar
I think Carista is a smart phone app. I'm not gonna pay a fee for that every year. I have Torque for my phone (another App with a one time fee) but if I want to change something, I prefer to use my laptop and use what Toyota/Lexus techs are using.
Old 03-16-18, 10:57 AM
jollick
jollick's Avatar
Thanks.Does that work on a computer? I passed on the whole smart phone/ cell phone craze.
Yes smartphone only and you pay either a one time fee for a month of usage or a yearly fee. I guess you will need another alternative. Good luck and report back what you end up doing.
Old 03-16-18, 12:51 PM
gamma742
gamma742's Avatar
Will this connector work w/ the software I found online? From the reviews, the software that comes w/ it is worthless. Just talking about the hardware. Latest software I could find was techstream V12.20.024 released (Sep. 2017) .
Looks identical to mine
xBROKER (03-16-18)
Old 03-17-18, 07:45 AM
jollick
jollick's Avatar
I gave up on that one. There is a program I tested that enables smart phone apps on computer. More trouble than it's worth. Can do more w/ techstream for le$$ aggravation. Found a good cable.
I have an iPhone so it is easy and I was one of the lucky ones that bought Carista it first came out so I paid once and no subscription needed to keep it working.
Quick Reply: Steering Wheel memory personalized settings 2013
