ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
2013 es350 dtc p0343 & p0335?
Old 12-11-17, 10:44 AM
Aman
Aman's Avatar
Exclamation 2013 es350 dtc p0343 & p0335?
Hello all.
My 2013 Es350 is giving P0343 & P0335 codes, which refer to Camshaft Position SEnsor "A" Circuit fault.
It appears only on low speed, I think. Two days back, I drove about 250 km and didn't get the fault during the long drive.
But today it appeared twice ( after resetting).
Can someone help me with their experience?
I want to locate the sensor and check the electrical connections by myself.
Is there any chance of Doing it myself?
Thanks.
Old 12-11-17, 08:41 PM
DanZ
DanZ's Avatar
The camshaft sensor is just below the air box. See this video of Camry, which has the same engine as Lexus es.
I think 2013 is much too soon for the sensor to go bad. It is likely that particles in oil might have jammed it, especially if the oil change frequency was not kept on it. Another possibility is the wiring, which you can follow in the video.
What is the maintenance history on this car? How many miles? Did oil sludge in it (you can tell that by just opening the oil cap on engine and looking at the deposit inside the oil cap)?
Aman (12-12-17)
Old 12-12-17, 04:17 AM
NdYAG
NdYAG's Avatar
Default There is a service bulletin about this problem.
A dealer needs to reprogram ECU to make these codes to go away. Service bulletin SB-0096-14.
Old 12-12-17, 12:34 PM
Aman
Aman's Avatar
Thank you alot for the reply.
I have recently bought it from a used car market and I don't have maintenance history of this car. The car appears to be very clean and new but doesn't seem to have been maintained properly, as the Engine oil was found very dirty which I have had replaced.
It has got 69000 km on it. I have replace the air intake filter, which was also in very bad condition and reset the faults again.
Could it be that I need to remove and clean the sensor tip?
I have not paid attention to the engine oil deposits inside the cap.
I will try to access the sensor connections to start with.
Tomorrow's driving will give update me and I will update here as well.
Thanks
Old 12-12-17, 12:37 PM
Aman
Aman's Avatar
Thank you for this information.
I have yet to read this SB and see if it really applies for the cars in UAE.
Old 12-12-17, 01:46 PM
NdYAG
NdYAG's Avatar
Sorry, I have rushed posting it. It seems that service bulletin only applies to the ES300h. Since you have ES350 it does not apply.
Aman (12-13-17)
Old 12-12-17, 02:20 PM
DanZ
DanZ's Avatar
Thanks
It is possible that cleaning the sensor tip might work. But it may return if the engine has sludge or particle deposits in it. You might try cleaning with one of BG products first, and then clean the sensor.
Aman (12-26-17)
Old 12-19-17, 12:15 AM
Aman
Aman's Avatar
Thumbs up Update : The fault has gone.
I checked the wiring for the sensor and tightened them here and there, it's been a week or so and the fault has not come back on yet.
Thank you all for the help.
CDeLappe
06-23-18 03:07 PM
xenonrider
01-01-10 03:29 PM
Brando
07-26-08 05:12 AM
Quick Reply: 2013 es350 dtc p0343 & p0335?
