Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
Battery ES300H
Old 06-03-17, 04:42 PM
GES
GES's Avatar
I checked my 300h car battery and here is what is stamped on it:
D26(JIS)
20 HR 57Ah
CCA 450A
Anny99 (11-29-23)
Old 06-04-17, 12:35 PM
jollick
jollick's Avatar
D26(JIS)
20 HR 57Ah
CCA 450A
I did a search and came up empty. This is from Lexus:
Battery: 12-Volt (Auxiliary Battery)he original-equipment 12-volt battery, located behind the rear seats, is a sealed, maintenance-free special application battery that is different from a conventional automotive battery.
Replacement batteries are available from your Lexus dealership. :-(
The only thing I can think of why it is different as it is in an enclosed area and not under a non-sealed hood.
Old 06-04-17, 03:15 PM
GES
GES's Avatar
I agree. This is not a conventional car battery. I think The D26 indicates the size and what type of battery it is. It is an AGM battery, like bc6152 mentioned. It is sealed, maintenance free and from what I read it lasts longer than a conventional battery.
I am wondering whether you can get this battery from other sources other than Lexus knowing what type of battery it is.
If anybody manages to get this battery from other sources and it works, I hope they post their experience on this forum.
Old 06-04-17, 03:32 PM
bc6152
bc6152's Avatar
Received 1,236 Likes on 868 Posts
As previously mentioned, the battery is available online and at various retail outlets for substantially less than $375.00...
Old 06-05-17, 11:13 AM
jollick
jollick's Avatar
Can you post a link to one online or retail outlook? I tried Advanced, Rock and Pep-Boys and they say they do not have one for the ES300h. I saw posts that Toyota dealers charge $375 for the Avalon 12v Battery. Thankfully I do not need one now but someday I will and want to know my choices. Thanks bc.
Old 06-05-17, 12:33 PM
bc6152
bc6152's Avatar
Online, I found a Bosch AGM S6 High Performance 12V auto battery available at Pep Boys here in Pennsylvania. The battery line is an S6 - S5 - S4 with S6 being top of the line.
S6 High Performance AGM™ Battery
Bosch S6 High Performance AGM™ Batteries provide excellent charge acceptance & peak power for vehicles with start/stop systems, regenerative braking & the highest electronic demand. The S6 features AGM™ technology & satisfies the highest starting & power supply standards even in extreme hot & cold climates.
Key Features
  • Up to 2X longer life* than conventional starter batteries
  • Constant power even for short trips, stop-and-go traffic or high consumption in stationary mode
  • Latest technology for start/stop applications
  • 4-year free replacement warranty
  • Free Road Side Assistance**
Explore Benefits
*Indicates cycle life of battery **Free for first 3 years from the date of purchase
Old 06-05-17, 12:46 PM
bc6152
bc6152's Avatar
Also available at Walmart for $219.95.
https://www.walmart.com/ip/Bosch-S6-...&wl13=&veh=sem
And Pep Boys: https://www.pepboys.com/product/details/838838/00380
Rafadog (03-01-19)
Old 06-05-17, 02:37 PM
GES
GES's Avatar
If the AGM battery lasts up to 2x the life of conventional battery this means that this battery should last at least 10 years. In that case even if you paid $375, it is still not a bad deal. And for a lot of people this would be maximum one time in the ownership period.
Old 06-06-17, 03:49 AM
Freds430
Freds430's Avatar
Received 1,059 Likes on 693 Posts
Both Walmart and Pepboys sites when you search under a ES300h or RX 450h no battery fit shows.
Old 06-06-17, 04:45 AM
Mike728
Mike728's Avatar
This Optima says it fits the Prius: https://www.optimabatteries.com/en-u...ttery/ds46b24r
I wonder why it wouldn't work in the ESh.
Old 06-06-17, 07:22 AM
GES
GES's Avatar
I think If you can find a battery that matches group size: S65D26R and minimum CCA 450A then it would fit
Old 06-06-17, 08:30 AM
GES
GES's Avatar
This is a picture of the battery
Old 09-13-18, 09:25 AM
mrBillFL
mrBillFL's Avatar
FYI I got 8 years.
mine died today. clicking and humming. for a while I could not turn it off. or open trunk.
looks like lexus is only one to carry it.
Old 09-13-18, 09:43 AM
Mike728
Mike728's Avatar
Originally Posted by mrBillFL
FYI I got 8 years.
You have an 8 year old 300h?
Old 09-13-18, 09:48 AM
GES
GES's Avatar
FYI I got 8 years.
Wow this is less than what I expected. I have had regular batteries last longer than that. Maybe the hot weather in Florida shortens the life of a battery. I have couple questions. How many miles you have on the car? and do you keep your car in a covered garage while at work and when parked at home or not? but,Thanks for the feed back anyways.
Quick Reply: Battery ES300H
