Do you like ES300h rear suspension structure ?
The forthcoming Camry/Avalon/7ES has a "compact" multilink rear suspension, to keep the rear wheels more perpendicular to the road surface to maximize grip, yet take up little trunk space, and still keep the costs under control.
For a genuine double wishbone front [double so that the front wheels can steer], and a genuine multilink rear - go for a midsize GS, but then it is a more expensive car.
You get what you pay for.
But with all due respect, where is the hard data that this more complex setup would perform better for a family sedan? I had a Mazda Melania which had this more complex rear suspension, and it was in good condition. Any significant sudden steering input (e.g. To avoid a cell phone toting driver drifting into my space) at 60mph was scary because it handled like a pig. My ESh seems to behave much more predictably In similar conditions. So I don't understand the benefit for an ES class car without the data. I have no doubt that this may help a Porsche or Ferrari zip faster around curves.
Is the suspension actually any different from the Es350's? Or is the the same setup on hybrid as ES350?
Also people talk about the battery weight effect, but apparently it's only about 120 pounds so not a huge amount of weight
I think it is the same suspension. I think it is all about damping rates, springs, and unsprung to sprung weight. Tires are the most important. I think suspension design impacts the angle of the axle as the wheel moves but not sure how significant it is relative to other factors. ESh has slightly better front back weight distribution because of the battery in the back and smaller engine up front relative to ES.
It was a very good handling car, but the ride was firm due to both the springing/damping and the lower profile tires.
The Millenia was better handling than the MacPherson strut ES300 of that time.
The first gen ES300 [nee 2nd gen ES] had a very short wheelbase, some 4" shorter in fact for an even heavier front/rear weight distribution, and the ES300's coils were firm too to minimize weight transfer to the outside wheels, although the ES had softer and floatier shock absorbers.
I can't remember if those Millenia had active four wheel steering too?
However, I thought the ES300 looked much better, especially on the inside.
The ES was also more spacious, though the ES was no match for the spaciousness of the Camry at that time...
https://www.clublexus.com/forums/es-...ml#post8591820
mlinn1967
Suspension
08-08-16 06:50 PM
