2013 ES 300h Driver Seat height Adjustment
Just checking to see if anyone out there has had a problem with the ability to adjust the driver's side seat low enough to be comfortable? My observation is the entire seat will lower to a specific point; then the rear portion of the seat then continues to go lower, as the forward portion just merely pivots.
I'd be fine with that but then the seat back also tilts back; and any attempt to adjust the setback to a more vertical position is just not possible.
I prefer to sit more vertical as this eliminates pressure on my neck and keep my upper cervical spine more vertical to prevent neck pain.
In comparison, the passenger seat can be adjusted much lower and doesn't reach a pivot point like the driver's seat.
Hey I'm not a giant! I'm 6' 1" with a 39 inch sitting height (why I know that is another story). I've gone to the dealership and they everything is 'normal'. How do other folks 6' 2"+ sit comfortably?
Just checking to see if anyone else out there has a similar experience? Thanks for your time.
mulasien
10-11-13 11:00 AM
