Black dashboard has a faded spot
Hi guys, I have a problem with my dash on a 13 ES. There was a shiny spot in the middle of the dash, so I took some Dawn dish washing liquid and a microwfiber towel and gently tried to remove the shiny spot. Well, after I wiped it with clean water, it dried as a whitish spot now, as if some of the dye came off! Can anyone suggest a remedy for this mistake I did?
Thanks.
Thanks.
When my car was delivered, the delivery guy tossed the owners manual on the dash. It made a white spot. It seems the dash material is very susceptible to abrasion. The micro-scale scratches make the whitish appearance. Almost any touch will make white scratches.
Someone on this board suggested a product called 303 Aerospace Protectant. See, https://www.clublexus.com/forums/es-...g-on-dash.html . The stuff works...
In addition to making the whitish micro-abrasions black again, it also protects against UV, and does not make it shiny.
Would a product like "Back to Black" work? It seems the whole dash is kind of faded though out.
try aerospace 303 first..it is what i use with great results. it will darken/deepen the original color and produce a slight sheen, but nothing like armorall. great product....
I bought the 303 product about a month ago. Used it on the dash and seat with great results. I does produce a film on the inside of the windshield for a few days. It has lasted well and much better than the oily Armour All products I was using.
Has anyone heard of Black Wow Trim Restore, and if so, is it any good?
2013 ES Cerulean Blue
You know, I think the more you fool around with the surface of the dash, the more can of worms you'll open. I also have a '13 and have applied nothing but a damp, soft cotton towel on the top of the dash to eliminate dust. I haven't had any issues with spots, gloss, wear, or anything else. I believe once you start applying any chemicals there, you're tied into using them all the time to maintain the appearance.
The reason why I ask about other products is I'm not sure if the products mentioned here are going to cover up the faded spots. What I mean by faded is that the black is lighter than the rest of the dash. So, I'm thinking maybe I need a product with some kind of black tint to it. More like a restorer than a clear protectant.
I went and found the threads on the detailing forum for you:
https://www.clublexus.com/forums/aut...rotectant.html
https://www.clublexus.com/forums/aut...ace-303-a.html
Thanks guys for all your input. I'll go to the detailing forum. Thanks again!
Is there some particular reason you don't want to try the 303? LOL
There is no reason. I just want to make sure I don't get a shinny dash, thats all.
I am thinking of trying 303.
303 does have SOME sheen, but it's very subtle. In order to even out the appearance of the dash you need something with some sheen though.
