ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Headlamp condensation
Old 02-28-13, 09:21 AM
jackson808
jackson808's Avatar
Default Headlamp condensation
Hi all, I have an 08 ES 350 that has condensation forming in the drivers side headlamp area. I brought it in for servicing and was told that it would cost $1,350 to replace the entire unit.It's out of warranty. Seems far too expensive. Anyone have any ideas or alternative thoughts?
Thanks, Jack
Old 02-28-13, 09:29 AM
unowned
unowned's Avatar
bake the headlamps so you can pull them apart and add new sealant. I forgot the temperatures since it's been a long time. Should be some youtube videos on resealing headlamps.
Old 02-28-13, 10:36 AM
jollick
jollick's Avatar
Thanks, Jack
I had this happen once on my wife's 2006 GS300 AWD. I took the HID bulb out and used a hair dryer, took an hour or more of it blowing warm air into the assembly, but all the moisture dried up, I put the bulb back in and have never had the issue again. Perhaps the bulb was not sealed completely and allowed air into the housing.
Old 02-28-13, 11:06 AM
bigblack06
bigblack06's Avatar
Thanks, Jack
First you posted in the wrong section. I had this issue as well, and I went through warranty. I got both replaced but it was a pain in the a$% to get done, a lot of back and forth to Lexus corp and to my dealership. I would try to get a goodwill repair if the warranty just went out, or try to contact Lexus corp and see what they can do.
Old 02-28-13, 05:24 PM
mrBillFL
mrBillFL's Avatar
I've used the hair drier method and vasoline around the seams and seals, with good results.
YMMV
Cjrosell
04-20-17 06:31 AM
onthefly11
Lighting
12-10-14 11:29 AM
Tnimri
06-07-10 09:57 PM
MLPTK
ES - 5th Gen (2007-2012)
05-06-10 07:57 PM
MVP
06-11-09 10:02 AM
Quick Reply: Headlamp condensation
