Brake upgrade for 2013 ES350
Hello Lexus People!
I've just upgraded brakes on my 2013 Lexus ES350, bigger rotors in front, and dual-piston calipers. They are just amazing! Pictures below, new and old. https://cimg4.ibsrv.net/gimg/www.clu...af17f60c61.jpg https://cimg8.ibsrv.net/gimg/www.clu...5333d23636.jpg https://cimg2.ibsrv.net/gimg/www.clu...626a1e6622.jpg https://cimg5.ibsrv.net/gimg/www.clu...35ade3ee61.jpg https://cimg8.ibsrv.net/gimg/www.clu...902afec5ed.jpg |
Did you use rotor, caliper and caliper bracket from Highlander or this is something else?
Originally Posted by BB9
(Post 11309911)
Originally Posted by RafNYC
(Post 11309915)
yes it looks like you know the magic trick - from Highlander. They fit perfectly
Curious, what year(s) highlander?
Originally Posted by st1800
(Post 11310194)
Originally Posted by cmrtopher
(Post 11310735)
I also would like to know. I’m about to do a brake job on mine, would be nice to upgrade. I plan on getting some drilled and slotted rotors too, so new twin piston calipers would be awesome.
So, after doing some digging, it appears that Highlanders and Siennas from ~2010-2019 have the same front brakes. If you're looking for a more sporty set of brakes, PowerStop makes a kit with painted calipers, drilled and slotted rotors, and "sport" pads. PN: KC4713A
The PNs for the brackets are 47722-0E030 (Left), and 47721-0E030(Right). I use the tow set on my Tundra, and I've loved them so far. My wife is bad to warp rotors due to her driving habits, so I've learned to upgrade her brakes to drilled/slotted rotors lol. Did you also have to replace the brake shields? Edited to remove hyperlinks from part numbers |
(Post 11311079)
The PNs for the brackets are 47722-0E030 (Left), and 47721-0E030 (Right). I use the tow set on my Tundra, and I've loved them so far. My wife is bad to warp rotors due to her driving habits, so I've learned to upgrade her brakes to drilled/slotted rotors lol. Did you also have to replace the brake shields? |
Those cheap no-name drilled rotors will often crack over time between the holes, and prematurely fail.
First time I heard about the ES/Highlander brake swap. Wish I knew about this months back. I did replace the rotors on mine with coated Centric rotors and Alebono pads, it noticeably braked better, but what really improved everything was bleeding/purging all the old brake fluid through the entire system with new. I'm sure the Highlander brakes work great by having a larger geometry... but for everyday use, I'm happy with how my car is now. I don't know if the rewards would outweigh the costs. |
(Post 11311363)
Looks like the website you are promoting has crazy overpriced item. Just 1 caliper bracket$130? Fully a rip off. On Amazon full caliper with bracket is $70 and it's perfect. Also drilled/slotted rotors is the biggest waste of money in brakes. Doesn't do anything else that make you change your brake pads faster and they create tons of brake pads dust. Do not recommend at all. With the time holes get filed with a brake pads dust and driller rotors look just terrible. Bosch quiet cast rotors and brakes pads on Amazon have just perfect price and quality.
Originally Posted by ptthere
(Post 11311410)
(Post 11311410)
First time I heard about the ES/Highlander brake swap. Wish I knew about this months back. I did replace the rotors on mine with coated Centric rotors and Alebono pads, it noticeably braked better, but what really improved everything was bleeding/purging all the old brake fluid through the entire system with new. I'm sure the Highlander brakes work great by having a larger geometry... but for everyday use, I'm happy with how my car is now. I don't know if the rewards would outweigh the costs. https://cimg1.ibsrv.net/gimg/www.clu...0a6a9582a3.jpg |
Do the rears from the Highlander also swap in? I'm not sure they're much of an improvement, but thought I'd ask the hive mind here.
From my findings, the highlander is a 309mm, whereas the ES is a 280mm. |
(Post 11311889)
From my findings, the highlander is a 309mm, whereas the ES is a 280mm. And yes, the diameter of Highlander front rotors is much bigger than diameter of Lexus rotors |
| All times are GMT -7. The time now is 01:36 PM. |
