ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   iphone cord stuck under seat! HELP!!! (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/982419-iphone-cord-stuck-under-seat-help.html)
nycowner Mar 8, 2022 07:19 AM
2016 ES 350 - iphone cord charging end (the part that goes into the phone) somehow got stuck under the seat (in the driver seat mechanism??). No matter what I do, moving seat forward, backward, up, down, the cord is stuck. I was about to just cut the cord, because the seat seems to be operating normally otherwise, but thought I'd check with the experts. I am not especially handy, so I am hoping that the solution does not involve removing the seat. Any helpful suggestions would be appreciated.
mandyfig Mar 8, 2022 08:28 AM
Unfortunately the only way you can find out is to get in there and look. I hand held mirror with a flashlight will help, or else use for phone and set it on camera and start looking. Good luck.
Kijug Mar 8, 2022 01:55 PM
First, remove the engine. Next.... =)
Yea the only thing to do is get down and look under the seat with a flashlight to see where things are and if you can un-stick the cord--or to find out if it is embedded in the seat moving gears, etc. That probably wouldn't be good.
703 Mar 8, 2022 08:52 PM
Highly unlikely you need to remove anything. Have someone small with small hands to go take a look. Or use a borescope.
