Offset for new wheels?
Old Aug 26, 2021 | 11:48 AM
2018ES350's Avatar
2018ES350
Originally Posted by Tootsall
I use a set of programmable Autel sensors on my second set of wheels without any problems (the tire dealer “read” the oem codes and programmed the same ids into the Autels); but different people on here have reported grief getting anything but oem to work. The key is to get a set that can be matched to the id codes of your existing oems or you will need to get the dealer to reprogram the car’s computor every time you switch wheels. The ES can only handle one set of codes unlike some other models that will take two sets of codes. At seasonal change I just mount the second set of wheels, make sure the pressures are right, hit the reset button under the dash and that’s it. As I warned, others haven’t been as lucky (or didn’t get a knowledgeable tire technition to do the supply/install).
Thanks, I'll look into the Autel stuff. I would normally go with OEM sensors, but I don't have a problem buying aftermarket programmable ones if the quality is as good as originals. I had a unit for reprogramming the new sensor numbers into my 2013 X-Runner, but I did that a few years ago and now when I need it I can't find the unit. It was one of the lower cost ones that plug into the port under the dash.
I went to the Autel site, and saw that they sell units that will ping the original sensors to determine their code number, so the new ones can be reprogrammed. I'd definitely be tempted to buy one of those if they aren't ridiculously priced. I'll have to research a little more unless someone can point me in the right direction
Old Aug 26, 2021 | 11:52 AM
Tootsall's Avatar
Tootsall
My tire dealer had the hand-held unit that pings the oems and then writes that id to the Autels. There is also the Carista OBD2 app and dongle that will read the oem codes…they have a utube video on using it on a Toyota product. I have that unit but only used it to confirm the id codes.
I have the Autels on my summer, aftermarket rims for two summers now with no issues.
Old Aug 26, 2021 | 12:26 PM
2018ES350's Avatar
2018ES350
Thanks, I'll check those out. Btw I found the unit that I used on my Tacoma, it's a ATEQ TPM Quickset.
Old Aug 28, 2021 | 06:39 AM
2018ES350's Avatar
2018ES350
Thanks for your help with the sensors. I ended up buying an Autel TS508K. This looks like a nice tool that will also help with the other vehicles I own when the time comes.
D3V3LOP3R
Wheels, Tires & Brakes Forum
Dec 23, 2015 07:00 PM
Coastal
Jul 1, 2010 09:16 PM
Kuriboh4
Dec 29, 2009 10:12 PM
YupImJOee
GS - 1st Gen (1993-1997)
Feb 25, 2009 03:39 AM
