ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Crack noise when opening driver door (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/952899-crack-noise-when-opening-driver-door.html)
websurfer Sep 14, 2020 03:32 PM
We have a 2016 Lexus ES350 with 42K miles as a CPO vehicle. When we swing open the driver door, it will sound something crack open. I looked around and there wasn't anything loose. The front passenger door doesn't make that sound at all.
Any ideas?
zes Sep 14, 2020 09:36 PM
The the sound occur when the door is opened a specific angle?
Did you try squirting lubricant in the door hardware?
websurfer Sep 14, 2020 09:52 PM
Yes, when I open the door even on a flat surface. I already put 3-in-1 oil around the hinges and it didn't make a difference so far today. I wonder if other ES350 have this similar issue?
bc6152 Sep 15, 2020 07:34 AM
I'd try shooting some WD-40 on the inside of the door post where the hinges are attached. As long as the door is not misaligned...
wdlugitch Sep 15, 2020 09:56 AM
Any ideas?
How about a visit to the dealer since it appears you are in warranty? Let them fix it.
websurfer Sep 15, 2020 10:15 AM
My wife already asked the dealer, they said it's that way. The passenger side door doesn't have that issue.
I'll probably go with her again on the next visit. I can also try the WD-40. I have WD-40.
Thanks all.
Littleguy Sep 15, 2020 10:33 AM
I would use a silicon lubricant over WD-40.
websurfer Sep 15, 2020 10:40 AM
Any brand in particular?
Tootsall Sep 15, 2020 10:57 AM
WD-40 now has a branded silicon lubricant. I use that on my door gaskets in winter. Any chance the noise is coming from a sticky door gasket breaking free?
Littleguy Sep 15, 2020 11:37 AM
Like Tootsall suggested, any brand, even WD-40 will do, the silicon will just be a better lubricant that will last longer.
Tootsall Sep 15, 2020 12:08 PM
I’m referring to this stuff...
https://cimg7.ibsrv.net/gimg/www.clu...247dab6f1.jpeg
websurfer Sep 16, 2020 07:27 PM
I'll check it out later on Friday. I have WD-40. Thanks.
Nelexus88 Sep 17, 2020 06:04 AM
In addition to the hinges you should also lube the detent mechanism that holds the door open. Thats the rod you can see located between the upper and lower hinges.
Also check to see that the door edge and front fender are not touching each other, which can be caused by a minor fender bender.
websurfer Sep 18, 2020 06:39 PM
Seems to be somehow better after the lub. Thanks.
august49 Sep 24, 2020 03:04 PM
Had the same cracking sound on my 2018 passenger side when I opened the door. It was the window sticking to the gasket at the top of the window. Here in Florida the heat makes the black gaskets stick a bit more. Dealer put a special silicone on my window / door gaskets and they’ve been fine since.
