PSI in winter tires?
Old Nov 19, 2019 | 09:14 AM
Dejan13's Avatar
Dejan13
Default PSI in winter tires?
Im wondering what PSI should the tires be on a 2013 ES350. I know it says 33 on the door. Im in canada and winter is here and when i start the car the psi is around 32-33 but after driving on the highway it goes up to 35-36. I know this is due to the tires and air warming up. Is it bad for the tires or ride to have them at 35-36? I have new continental winter contact si tires and dont want them to wear out uneven. Im debating do i have them 33 when warm or 33 when cold?
Thanks in advance
Old Nov 19, 2019 | 02:07 PM
mcomer's Avatar
mcomer
Door placard PSI are to be measured when the tires are cold, ie. not been driven yet.
Ambient outside temperature is obviously going to vary greatly, but check them before driving.
As it is still relatively early into winter (USA, perhaps not Quebec!) your readings of plus 3 degrees
from cold after driving sound entirely normal.
Old Nov 19, 2019 | 02:54 PM
Dejan13's Avatar
Dejan13
So driving on 35-36psi wont wear my tires pre maturaly? Its not considered over inflated?
Old Nov 20, 2019 | 04:09 AM
Freds430's Avatar
Freds430
Will not wear tires nor considered over inflated at 36 psi. Remember for every 10 degrees drop in temperature your tires will lose one pound of pressure. I keep ours cold at 35 and will go as high as 38 on highway driving.
Old Nov 21, 2019 | 09:25 AM
Maikerusan's Avatar
Maikerusan
Thanks in advance
33 Cold. You alway use the setting on the door.
Never had an issue with this in many many years of Canadian driving.
lnettl1
Wheels, Tires & Brakes Forum
Jul 6, 2017 12:50 PM
wiloz32
IS F (2008-2014)
15
Oct 31, 2015 01:13 PM
bclexus
Mar 11, 2015 11:44 AM
luxury1
Oct 5, 2007 08:56 AM
morris
Dec 17, 2005 01:50 PM
