Audio Upgrade Completed.
Old Aug 22, 2018 | 05:40 AM
ALL4SPL's Avatar
ALL4SPL
Talking Audio Upgrade Completed.
I've been in the car audio hobby/industry for over 25 years and I always upgrade/replace the audio gear in my cars. This being my first Lexus it posed a problem, the source unit is not replaceable. So I set out with a few goals in mind, I wanted clean clear sound, as well as a moderate amount of bass. I come from a background of SPL competition, from db drag to IASCA including a few world records and as a world champion in 2016. However, as I said my goal was much different this time, I was going for a more Sound Quality oriented system with the ability to get a little loud if I wanted.
Here is a list of all the components used in my 2017 ES 350.
Source Unit conversion - Mosconi 4to6 DSP - http://mosconi-america.com/portfolio/dsp4to6/
Blue Tooth Module for DSP - http://mosconi-america.com/portfolio/bluetooth-module/
Front Stage - Focal Access 3way Components - https://www.focal.com/en/car-audio/c...t-kits/165-as3
Rear Stage - Focal Access Coaxials - https://www.focal.com/en/car-audio/c...al-kits/165-ac
Sub Stage - DD Audio 9512 12" Subwoofer - http://ddaudio.com/products/subwoofe...uned/dd9500-2/
Front & Rear Stage Amplification - DD Audio 4 channel Amp - http://ddaudio.com/products/amplifiers/c-series/c4-100/
Line Driver - Audio Control Overdrive - https://www.audiocontrol.com/car-aud...verdrive-plus/
Sub Stage Amplification - DD Audio M3C Amp - http://ddaudio.com/products/amplifiers/m-series/m3c/
XS Power D3400R Front Battery - https://4xspower.com/shop/12v-agm/d-series/d3400r/
Full Throttle G31 Rear Battery - http://www.fullriverbattery.com/prod...ries/FT1100-31
All factory locations where used for the speakers with the exception of the tweeters, those were flush mounted in the A-Pillars. The single 12" subwoofer was installed in a ported enclosure tuned around 35Hz, and all the components (DSP, Amps and Line Driver) were installed in the trunk behind panels. 0 Gauge wire was ran from the new front battery to the rear of the car to the rear battery. The Audio Control Line Driver was used on the sub stage amplifier as the output line voltage from the factory source unit was not enough to support the 4 channel amp and the sub amp. Before any of the install was done I removed all the rear trunk paneling and applied a single layer of 80ml sound deadening, this was applied at about a 75-80% coverage rate, additionally I put deadener on the trunk lid at about 40% coverage and then applied closed cell foam over the deadner. The install was handled by a shop a long time friend of mine works at Migraine Kustoms in Edgewater, FL.
I plan on doing more sound deadening in the doors, behind the rear seat and the rear deck. Overall the sound is MUCH MUCH better, the DSP give me full control via my laptop to adjust the EQ and time alignment for much better staging. The sub can get pretty loud but is also firing forward to avoid as much rattling as possible in the trunk.
Here are the photo's I have from when I did the trunk deadening and then shots of the sub and the trunk.
Old Aug 22, 2018 | 06:51 PM
Shawn350's Avatar
Shawn350
Very nice! Did you replace the 3 front dash speakers, or just omit them? I’m in the process of getting quots to install new speakers on my GS, and the guys are saying it would be best to use component speakers and put the 2 tweeters in the dash. So I was just wondering how it sounded if you didn’t replace the dash speakers .
That Lexus logo on you sub was an awesome touch.
Old Aug 23, 2018 | 02:26 AM
ALL4SPL's Avatar
ALL4SPL
The 3 way components up front used all factory locations so the A-pillar for the tweeter, 4" in the dash and 6.5" in the door. The only dash speaker not used was the center one.
jugdish
NX - 1st Gen (2015-2021)
Dec 6, 2016 12:20 PM
PxH_83
Apr 25, 2007 09:05 AM
insomniac
Feb 1, 2007 04:36 PM
Hameed
Jan 7, 2004 10:28 AM
