Navigation screen splits in half?
Old May 26, 2018 | 11:28 AM
nuraman00's Avatar
nuraman00
Default Navigation screen splits in half?
On my 2018 ES, it seems that when I'm on the freeway, the screen will sometimes split in half, vertically. And on the right hand side, it will tell me some info about upcoming exits (even if I'm not going to be taking them).
Sometimes, it will also have dining and ATM ($ icon) next to the upcoming exits.
What information is it trying to tell me? Can this setting be adjusted? I don't like having the map split in half. I'd rather see as much of the map as possible.
My 2013 ES didn't do this.
Old May 26, 2018 | 02:18 PM
digitalnrg's Avatar
digitalnrg
I believe they updated the map starting 2017 model
Old May 26, 2018 | 03:09 PM
nuraman00's Avatar
nuraman00
What exactly is the feature trying to do? And is this adjustable (on/off)?
Is it just telling me names of upcoming exits?
Old May 27, 2018 | 07:26 AM
Mike728's Avatar
Mike728
My 2013 does. There's a setting for it. However, I know nothing about your 2018.
Old May 27, 2018 | 07:50 AM
nuraman00's Avatar
nuraman00
What was the setting on your 2013 called? I might be able to find it on the 2018.
When I first got the 2018, I went through the settings and tried to turn off things I didn't think I would like. But I may have missed something.
Old May 28, 2018 | 08:03 AM
john341's Avatar
john341
Ok, try this. When the screen is displaying the map press "ON>>"; Then you will see "Map Mode" option on the left bottom of the screen, choose that and turn off dual map and or turn list. Hope this helps.
Old May 28, 2018 | 08:19 AM
lesz's Avatar
lesz
I believe that the purpose of the Map Mode setting is to allow you to simultaneously view the map on one side of the screen while viewing radio and/or climate control information on the other side of the screen. But I don't think that it has anything to do with the upcoming exit information that displays on the right side of the map screen when you are driving on a freeway/toll road.
I could be wrong, but I don't think that there is any way to disable that upcoming exit information the appears when you are driving on a freeway/toll road.
Old May 28, 2018 | 09:27 AM
gamma742's Avatar
gamma742
Yeah when you are receiving turn by turn instructions, it will split screen on you.. otherwise you can enjoy single screen mode.
Old May 29, 2018 | 06:47 AM
john341's Avatar
john341
Oh, Gotcha. Yea, I don't think there is a way to disable that.
Old May 29, 2018 | 01:56 PM
lesz's Avatar
lesz
When driving on a limited access highway, I actually find the information about upcoming exits to be very useful. On such limited access roads, every mile can look much the same, and the information about upcoming exits helps me to orient myself and know where I am, and it also provides an alert as to when I'm getting close to my exit.
Old May 29, 2018 | 08:48 PM
nuraman00's Avatar
nuraman00
Thanks. I checked this setting. Single map mode was already on. I switched in between dual mode, compass, and single map mode, just to make sure single map mode was on.
I don't think this will change anything, though.
I'm not going to go on the freeway for a few weeks, so we'll have to wait to see if it did anything.
Old May 29, 2018 | 08:50 PM
nuraman00's Avatar
nuraman00
What does Route Trace do? How can you see the trace of the route?
Does it color the route yellow?
Old May 30, 2018 | 03:03 PM
JDR76's Avatar
JDR76
It can be turned off.
1. Click the List icon on the map screen (looks like three horizontal lines).
2. Select Map Mode.
3. Deselect Freeway Exit List
In the past, to turn this off I've had to make this change while actually on the freeway, as that's when it's activated.
Route Trace will highlight your past route, so you can retrace it if you so choose. Kind of like bread crumb trails.
Old May 30, 2018 | 03:53 PM
nuraman00's Avatar
nuraman00
2. Select Map Mode.
Freeway Exit List was already de-selcted for me (grayed out). Yet I still saw the feature, when I posted of this.
Old May 30, 2018 | 04:30 PM
JDR76's Avatar
JDR76
Were you on the freeway when you tried this? Mine is always off unless I’m on the freeway. I had to turn it off while on the freeway.
