VIN Cover at Floor
Our 2015 ES 350 with 12,000 miles has a continual problem with the plastic VIN cover plate on the floor in front of the front passenger seat. It comes off very easily when barely touched. The dealership admits that they cannot fix it properly. Do others have the same problem and know of a permanent fix? Thank you very much! Ned
You can also easily find The VIN # on the left lower corner of the dashboard under the windshield when you look at it from outside the car. So you are not going to lose the VIN# even if you couldn't fix the drivers side door plate.
To the OP: I had the same issue early on with my 2013 ES but found that if properly seated the cover will stay on. This was nearly 5 years ago and it's still secure. GOOD LUCK!
ivanwang
Dec 18, 2015 11:36 AM
