ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Bluetooth Outgoing Call Inoperative (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/856251-bluetooth-outgoing-call-inoperative.html)
pmayerow May 12, 2017 02:14 PM
I have a Lexus ES 300h and an iPhone 6. Bluetooth was working appropriately. Intermittently outgoing calls would transmit but would not be heard via the Lexus speaker system but could be heard on the iPhone speaker or handset. Incoming calls worked fine. My dealer deleted the bluetooth settings on both iPhone and Car but the problem would still reappear intermittently. The same problem existed when another iPhone/Android would be connected to the system, so Tech Support concluded the problem was not the phone. They replaced the radio since the chip for bluetooth was a non-replaceable component of the radio motherboard. The bluetooth functioned correctly for 1 1/2 days and the intermittent problem reappeared. The car is going back into service. Has anyone had a similar problem and what was the fix?
mcomer May 13, 2017 02:12 PM
Might the steering wheel buttons,speech/talk,on hook,off hook, have suffered some sort
of damage? Spilled liquid or impact? These initiate and disconnect calls and may be involved.
pmayerow May 13, 2017 02:24 PM
This is probably not the solution since the problem also occurs if the call is initiated from the menu screen. In either case, the call is heard on the iPhone but not on the Lexus Bluetooth connection.
