Anything to know before disconnecting the battery?
I was curious if there is anything I ought to do before disconnecting the battery. Do I need a radio code? I want to add a bypass harness to the radio/GPS/DVD, and the instructions say I must disconnect the battery first.
tx |
I just did this on my sister's Honda. I don't know if you must have the radio code and password in hand to reactivate the radio when the battery is reinstalled in a Lexus. If you do, the information is on a card given to you when you buy the car. It should be in the glove box. If you lose the card it will cost you to obtain the information. A real PITA. The radio serial number is ON the radio. So check before you disconnect. You'll probably lose your radio presets as well.
Originally Posted by bc6152
(Post 8975468)
Call the dealer, I did this with a Honda too. Free
Some give it for free some don't...
honda's will have the 5 digit code on a sticker inside the glove box affixed to either side. no need to contact dealer...
If you have mercedes, there are lots of things to know before disconecting a battery! Other cars not so muc expect for the radio code.
Originally Posted by wowzer
(Post 8975406)
tx |
I've changed out my batteries my older RX and GS without any issues.
Great. I will try to make the install this weekend. Thanks for the info everyone (crossing fingers). I'll try to post a video on the install.
| All times are GMT -7. The time now is 09:27 AM. |
