ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Ideal 20" width and offset (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/734737-ideal-20-width-and-offset.html)
rhizzz Mar 20, 2014 07:09 PM
Hi guys Im looking on a set of gramlights 57XX in 20s. Does anyone know the recommended width and offset? Im not sure if 20X8.5 +45 or 20X9.0 +45. And also the tire size. Thanks!
RAMON702 Mar 21, 2014 04:17 AM
I have 20x9 +38 offset and its perfectly flush with the fenders. Also using 245/35/R20 tires.
LexRuger Mar 21, 2014 09:52 AM
for a width of 8"-9" +35 to +45 would be fine. the lower the offset, the more they stick out. a higher offset would make the wheel more sunken into the wheel well more. if +45 is too sunken in, you could just use spacers to make them more flush with the fender if you wanted.
rhizzz Mar 21, 2014 10:43 PM
thanks, big help
btw whats your suspension set up Ramon? did you use the 07 4-cyl camry springs as well?
RAMON702 Mar 24, 2014 03:53 AM
Yes I did Tein lowering springs
