2018 ES350 rear brake torque specs?
Hi, are these the correct torque specs for a 2018 ES350?
Rear caliper bolt: 20 ft lbs Rear caliper bracket bolt: 46 or 58 ft lbs? (some youtube videos have either) Front caliper bolt: 25 ft lbs Front caliper bracket bolt: 79 ft lbs Thanks! |
The 6th gen ES is built on the same platform as the 2013+ Toyota Avalon. Same brakes and suspension. 58 pounds torque for the rear.
This has been asked before: https://www.clublexus.com/forums/es-...thickness.html https://www.clublexus.com/forums/es-...rake-pads.html This is from the Haynes Manual https://www.toyotanation.com/attachm...igh&width=1920 |
Hmm, official Lexus service manual disagrees with Haynes:
https://cimg7.ibsrv.net/gimg/www.clu...97793a827c.png Not a big difference but nevertheless makes Haynes numbers now suspicious. |
| All times are GMT -7. The time now is 08:15 AM. |
