ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Amp refurbish on ebay (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/1043837-amp-refurbish-on-ebay.html)
Mhn Sep 12, 2025 07:03 AM
Have a 2013 es 350 with Mark levinson system. Believe amp is bad. Anybody had luck with the refurbished ones on E bay for $599.00. There called OEM Auto Audio.
larrytstar Sep 13, 2025 11:39 AM
Hi Mhn. I have the same car with the same problem. Do you know the part number for our amp? Our amp is different than the non-ML car. Thanks.
Mhn Sep 13, 2025 05:43 PM
Yes it's # 86280-OWA70
https://cimg9.ibsrv.net/gimg/www.clu...d7f6bec7fe.jpg
Here it is.
larrytstar Sep 14, 2025 10:53 AM
Super. Thank you Mhn.
Mhn Sep 24, 2025 10:32 AM
Amp refurbish.
Have currently sent my Mark Levinson amplifier off to be repaired. Will give updates when it comes back from OEM Auto audio.
Mhn Oct 5, 2025 07:41 AM
OEM Auto Audio.
After receiving my Mark Levinson amplifer back from OEM Auto Audio and installing it I'm pleased to say everything works as it should. Also has a one year guarantee. All in all it was about $640.00 dollars which I thought was reasonable. No telling how much if you took it to a dealer or Audio shop. Highly recommended.
larrytstar Oct 5, 2025 07:37 PM
Great news Mhn. How long was the turn around?
Mhn Oct 6, 2025 05:25 AM
About 8 days. Make sure you pack it in a small box like a shoe box with plenty of bubble wrap. Take all mounting brackets off. I had trouble with the mounting bracket screws but some wd 40 helped. Put it on and let it sit for awhile. Good luck.
