2014 es 350 po303
Old Jul 14, 2025 | 05:18 AM
kauaiboy's Avatar
kauaiboy
1st Gear
Default 2014 es 350 po303
Need help, I have replaced the plugs and coil pack, done leak down, compression test, swapped fuel injector, what else should I check? Engine light comes on after warm up. On diagnostic misfire resets constantly.
Old Jul 14, 2025 | 06:12 AM
Clutchless's Avatar
Clutchless
Welcome to CL.
How many miles are on it?
Check for codes? You need to know what the car thinks is the problem before throwing parts at it.
Make sure none of the coil wires or connectors are broken and that no varmints have eaten your wiring.
What brand coils and spark plugs did you use?
Mjees
ES - 7th Gen (2019-2025)
May 30, 2023 01:43 AM
CDLAST07
May 7, 2023 02:42 PM
1rarees
Apr 24, 2023 08:16 AM
Marc39
55
Apr 18, 2023 02:15 PM
SFalero
Jun 28, 2017 05:08 PM
