ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Passenger Side View Mirror stopped working (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/1038835-passenger-side-view-mirror-stopped-working.html)
brucelee1 Apr 25, 2025 06:24 AM
Hello all,
2013 Es350. Passenger door side view mirror just stopped working ie, is not adjustable. Driver's side works just fine. Any thoughts? Possible fuse issue, I hope?
Thank you.
larrytstar Apr 27, 2025 12:11 PM
Hi Bruce. I have the same car and mine stopped working too. All I can offer is sympathy, as I never found a simple solution or had it repaired. Given that I am the only person who drives the car, I just manually put into position and never have need for it to be changed. I'll be interested to hear what you do. Thanks.
brucelee1 Apr 27, 2025 12:17 PM
Thanks, if I am able to move it, I likely will do the same.
I will keep you posted.
dmuff Apr 27, 2025 05:17 PM
It's usually the brushes/contacts on the motors getting gunked up over time. Here's some good info:
https://www.clublexus.com/forums/gs-...motor-fix.html
brucelee1 Apr 28, 2025 04:59 AM
Funny. I manually adjusted it, heard it click and boom, the adjustment started working, again! Cool.
brucelee1 Apr 28, 2025 05:00 AM
Thank you.
larrytstar Apr 28, 2025 12:53 PM
Bruce, that happened to me too. I move it and it worked intermittently for a while and then finally stopped altogether.
Interesting repair thread! Very well presented and explained. Not that I will do it, but good to know it's out there.
brucelee1 Apr 28, 2025 01:33 PM
I do not intend to change that setting for the remainder of my lifetime!!!!!!!
