Headlight Wiring Harness
Old Nov 3, 2024 | 12:35 PM
SCTPTETWN's Avatar
SCTPTETWN
4th Gear
Default Headlight Wiring Harness
2013 ES 350
I just changed the HID bulbs on both sides of my car and one will not come on. I used the bulb in both Pass-side and Driver side and it seems to be good but it will not come on on the driver side. What else can I do? The fuses are all good....... Is there a relay or could my wiring harness be bad?
Old Nov 3, 2024 | 05:13 PM
is250916's Avatar
is250916
Ballast could be bad. Get the ballast from passenger side and install it on the driver side.
Old Nov 5, 2024 | 11:01 AM
jgscott's Avatar
jgscott
Was the driver side working right before you went and changed the bulbs?
Old Nov 5, 2024 | 06:11 PM
SCTPTETWN's Avatar
SCTPTETWN
4th Gear
Negative. Drivers side was the dead side.
Old Nov 7, 2024 | 10:21 AM
jgscott's Avatar
jgscott
Where did you get the Bulbs, - Brand?
I would switch the known good side bulb, into that side. See if works? Be sure you have it seated correctly with the Clip over in. It's a PITA changing those blubs, and being sure they seat in correctly. If seated correctly could be the Bulb. I would check that before the ballast.
Old Nov 7, 2024 | 12:00 PM
SCTPTETWN's Avatar
SCTPTETWN
4th Gear
I used the burning bulb from the passenger side on the passenger side and it did not work. I then replaced the passenger side with the new bulb and it worked there. So I have two “good” bulbs that work on the passenger side. I bought a SylvaniaDS4 High Intensity Discharge HID HEADLIGHT BULB. It works on the passenger but not in the driver side…… I saw how difficult it is to pull the ballast off…… I was praying it was not that.
Old Dec 21, 2024 | 05:54 AM
SCTPTETWN's Avatar
SCTPTETWN
4th Gear
Welp, it was indeed the ballast that failed. The reason it failed was water intrusion into the headlamp assembly. I found that out when I replaced the ballast and the new one crapped the bed. Now I need a new headlamp assembly. of course I ordered one from Ebay and it arrived without a hole for the orange marker lamp/bulb. I sent it back and need to find one with a hole for that light. An OEM is freaking pricey!
Aysly
Dec 31, 2023 11:32 PM
melski415
Sep 13, 2012 08:46 PM
olmytsi
Florida Lexus Club
Jan 28, 2011 01:19 PM
JDMis350
Feb 13, 2010 04:40 PM
daSC4
Lighting
13
Dec 5, 2007 12:14 PM
