SO....the latest info in our experience is, purchased a JDM tranny for $1,674 from jdmenginedirect.com. Be careful. Their name is JDM ENGINES DIRECT, but their website is NOT the plural of engine! Bad mistake on their webmaster!
The tranny had 55k miles on it, but I wasn't told from exactly what year/model it was from. I had it shipped to a well known mechanic/friend of the family who lives and hour away from us, after he said he would replace it, no problem, for $1,000! What a deal in my opinion! I bought a case of WS from local Lexus dealer for $150, and a transmission filter from local auto parts store for $18. Lexus wanted over $115 for the transmission filter! Anyway, with all that delivered, and about 8 days later, my mechanic said it was done! We picked it up today, and there's a slight odor of burning fluid (maybe trans or oil or penetrating fluid etc) that seemed to linger on the ride home. There's a very very slight hint of shudder in 6 gear and when climbing up a hill and before it shifts out of 6 to 5. That's the only issue that I have. Will that shudder become worse or disappear over time? Who knows. Is the trans fluid filled to the exact/proper level? Not sure. I did say to the mechanic the fill process/instructions are very lengthy and detailed and he acknowledged. During the swap he said it might have to go to the dealer for them to "flash" info into the ecu or cpu or whatever the brains of the car are. That turned out not needing to be done. He did return 2 full quarts of WS fluid along with a TCU (transmission control unit?) to us. I'm not sure if the TCU he returned to us is our original or he reused our original TCU and installed it onto the JDM tranny. I want to drive it for a couple weeks then attempt to perform a drain and fill, so that I can be assured the level is exactly spot on. However, not sure I want to f- with something that's operating 98% fine right now, not to mention I don't have the tools or space or time to properly check the WS fluid level! Perhaps we SELL the ES in several months, etc? It does have 105k on the odo. Wifey did NOT like that idea, and she doesn't like the idea of having a car payment. What do we think......with a very slight hint of shudder in 6th gear when going up an incline and barely pushing the pedal? Is it the trans trying to come out of overdrive? Can we say this is acting this way because the trans might be OVERfilled or could it be UNDERfilled, or should I just leave well enough alone? I'm thinking to give it some time to learn our driving habits? Finally, I did an engine oil change when we brought the ES home, just so I could put it on ramps and view the underside for leaks or to view the work done, harnesses, nuts/bolts/etc....and thank God I don't see any drips anywhere. The engine/trans mating surface looks dry. It looks better than what I thought it would be......although I still slightly smelled what I think is trans fluid burning, when I was leaning over the engine filling it with 0W-20 synthetic motor oil. Thoughts? |
Originally Posted by dstarling
(Post 11705153)
Probably error code P2757. Just got this code on my 2017 ES 350 with only 50K miles on it. Never noticed anything wrong with shifting or shuttering when braking all the years I have owned this car. I even brought it to the dealer for its 50K checkup and all was fine. After that, it sat at the dealer for 2 months waiting to get a fender replaced with a small dent. These enclosed transmissions with lifetime fluid are a mystery to me. I have never owned a car that had transmission issues and I have had manual and auto cars with high miles prior to this. I am still in shock over the $8600 price tag.
Originally Posted by LS430inDE.
(Post 11707476)
my mechanic requested I purchase a JDM tranny
SO....now the latest......wife said car wasn't shifting correctly in the afternoon. She was driving it intermittently since 9am. She said it wasn't shifting correctly and revving really high before shifting, and general shifting issues. I said pull over to the next available shopping center...and while she was, engine threw a code P2714 PRESSURE CONTROL SOLENIOD. Ironically, that's the same code the FIRST transmission gave, before the transmission went bad. Our mechanic REUSED the old Lexus transmission computer so that we wouldn't need to get the used tranny computer 'reflashed'.
Is it possible the original TRANS COMPUTER is faulty, which made the first/original tranny went bad? I'm about to take it to a highly rated trans specialty shop. Do you think a trans shop would be better at diagnosing and fixing this issue than the dealer? Looking for suggestions. |
Originally Posted by LeX2K
(Post 11703348)
Is that a reman from Lexus? MSRP for a new unit is $8,000. It would be helpful to get a 2nd opinion from an independent shop or transmission shop.
Since the dealer I believe will only replace transmissions with new ones, Im sure they have customers with transmission issues serious enough to warrant possible replacements or rebuilds after diagnosis. What I found is that here they actually refer you to a reputable Transmission specialist in the area (I got mine installed at AAMCO .. excellent job and service from the local shop/franchisee).
(Post 11715753)
I usually think the dealer is the #1 place to take a vehicle for accurate diagnosis (even though it may cost 3x more than an indy repair shop).
Yes I agree 100% .. what I meant to say earlier was that if you get a referral from the dealer, let the transmission specialist start off by diagnosing the
problem. In my case that's what happened but I had to source the replacement transmission and believe I was shocked at the prices we have to pay here in Canada for anything auto related .. |
I heard reflashing with dealer software and hardware was needed after any major transmission work, especially replacing one.
Hopefully that's your only issue. Solenoids might be bad too. Or, the transmission might be worn out and bad as well. You got warranty on parts and labors? |
This is exactly why I advised to take it to an independent transmission shop for a rebuild.
Now, if you are using the old TCU it is possible that the code is still in the memory, as well as the shift learned behavior. Get the TCU flashed before doing anything else. |
I don't think your mechanic have access to TIS and Techstream and has done all the necessary procedures.
E.g.PERFORM A ROAD TEST SO THE TCM CAN ADJUST Note Strictly obey all speed limits and traffic laws when performing the following activities.
Note Memory reset can only be performed using GTS. Tech Tips When controlling the automatic transmission and engine, the TCM (ECT) stores vehicle condition parameters in memory. Therefore, when replacing the automatic transmission assembly, valve body assembly, SL3 shift solenoid valve, SL4 shift solenoid valve, or TCM, a memory reset must be performed so that the TCM can store the new data in memory.
Tranny
(Post 11703344)
Yesterday the wife was on a 4 hour road trip to her gf's in upstate NY. The final hour or so of nearly 100% highway driving she said the transmission was acting funny. It was 1am and she didn't want to call me, and she certainly wasn't pulling over to the shoulder when no CEL illuminated and all gauges were normal.
She described if she lifted her foot from the accelerator, it would slow down drastically. She also heard grinding noises at various times. Near the end of the trip it was difficult to gain speed from a stop light. Don't ask me why did she continue to drive it. It was midnight, no dashboard lights illuminated, and all gauges showed normal. The 2014 has 105k miles. A tranny drain/filter/fill had never been done. I was trying to schedule this and do it myself. I do most of the work on her ES and my LS. Doing a drain and fill and filter change on the tranny most likely would not have prevented this disaster. She was able to drive it to a dealer 15 minutes away from her gf's house. While she was driving to the dealership, a CEL illuminated. She realized at the dealership, the car wouldn't go into reverse. The Lexus dealership (Burdick) called and said "a soleniod went bad" and it ruined the entire transmission. I forgot to ask what the code was. Their fix is to replace the entire tranny with a remanufactured tranny. He said fixing the tranny would cost more than simply replacing it. Their cost to replace the tranny with a reman, and provide a 1 year/12k mile warranty is $8,000. The vehicle was immaculate. I have documentation with all the maintenance I've performed on it. Until now, we were fortunate to only pay for wipers, oil, tires, filters, etc. We are 2nd owners, purchased it at 35k miles. What are our options regarding repairs? What would you do for repairs? What would you do in this situation? |
[QUOTE=Mikes01pet;11717315]so my granny went last July, no warning,
Originally Posted by Mikes01pet
(Post 11717315)
so my granny went last July, no warning, I paid $5640 for a tranny from japan which i was told only had 26000 miles on it. Guarnteed for 1 yr, but the mechanic said he would back me up if needed,?. Mine didn't give ant indication, I was on the highway also and all of a sudden it wouldn't go. Love my 2013 with 169000 miles on it so I paid for the repair.
Originally Posted by john2101
(Post 11715932)
| All times are GMT -7. The time now is 12:35 AM. |
