ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Check BSM system (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/1012198-check-bsm-system.html)
EEng Oct 18, 2023 07:13 AM
Check BSM system
I have had this '15 ES 350 for little over a week. Went on a road trip to see the eclipse. On the return trip this message popped up. I can't find how to read the code. Can anyone give me a clue what code reader to use or where to look to fix this?
Tootsall Oct 18, 2023 09:46 AM
If you use a desktop (MS), then some folks will recommend Techstream. Unfortunately it does not play well with Apple/Mac products. There are numerous OBD2 "dongles" available and they work with different apps. Personally I use the Carista app and dongle on Mac/OS. Just dive into your App store and see what you might prefer. Generally they aren't too expensive (I think I paid $20 for the Carista Dongle, got the first month of "pro level" scanning for free, and thereafter I pay about $10 for a week's use...which I don't bother with unless I see a problem pop up on the dash display...been a couple years now. The "free" use will give you codes but does not allow you to clear the codes, change the car's firmware settings (things like how/when to unlock doors, flash the blinkers for lane change, etc., etc.) Very useful if you have to take the car to a dealer...gives you advance notice of what codes might mean and provides a "verify" for what the service department will tell you. If you check out "Carista" (again, it's just what I use, not what you may select), on YouTube they post some videos of what it can do for Toyota/Lexus products including the TPMS sensors.
I don't have BSM on mine but it may indicate dirt on a sensor, broken sensor, loose connection....etc. I don't think that a code reader will help much with that but maybe someone else can shed more light. It may tell you which sensor is the problem and allow you to make the fix/change yourself saving a whole bunch of money that the dealer would charge.
EEng Oct 18, 2023 10:51 AM
I would like to get tech stream for Windows 10. Does anyone have a source? What about the cable?
komobu Oct 19, 2023 03:08 AM
You can find tech stream on ebay. The cable can be bought on ebay or amazon. Just do a search for toyota techstream cable.
EEng Oct 19, 2023 06:10 AM
Thank you very much
shoodes Oct 19, 2023 09:14 AM
https://forum.ih8mud.com/threads/how...nutes.1034923/
Here is Techstream made for a virtual machine. You can use a macbook or any windows laptop.
I bought a Techstream Cable off of Amazon for $34~
EEng Oct 19, 2023 09:43 AM
Thank you very much. This is helpful in more way than just Techstream. Kudos Kudos
