Coolant Flush and Brake bleed
Old Aug 1, 2023 | 06:34 PM
lexsc4's Avatar
lexsc4
Default Coolant Flush and Brake bleed
Hi all,
My 17 ES350 just hits 39K and I would like to flush the coolant and bleed the brakes fluid. Both have never been done before and it is now 6 years old.
I know I will need ~10 quarts of Super Long Life coolant, but I don't know how much DOT3 fluid I need, anymore knows?
TIA.
Old Aug 2, 2023 | 08:24 AM
ESh's Avatar
ESh
1 qt of DOT4.
Your coolant is good until 2027.
Old Aug 2, 2023 | 09:16 AM
bc6152's Avatar
bc6152
Coolant good for 100,000 miles... Just had two cars brakes bled and flushed at trusted independent garage. Both less than $100.00... One, a Honda, dealer wanted $420.00... Bought the brake fluid at Walmart...
Old Aug 2, 2023 | 09:57 AM
lexsc4's Avatar
lexsc4
Thanks all for the input. My ES350 is 6 years old so I figure just get both coolant and brake fluid flush out.
My mechanic will charge $150 labor and I supplies 3 gallon of coolant and 1 quart of brake fluid.
Any thought if I should get the coolant flushed out or am I wasting money?
Lexus dealer here wants $290 for the coolant job and $190 for the brake fluid job, that's a little high for my taste.
TIA.
Old Aug 2, 2023 | 11:28 AM
bc6152's Avatar
bc6152
I'd skip the coolant change and just have your guy do the brake fluid... I paid just under $100.00 but for northern Cali i guess $150. isn't too bad... My brother in Redding is always complaining...
GOOD LUCK!
Old Aug 2, 2023 | 11:53 AM
ESh's Avatar
ESh
I would skip the coolant. You should replace it at 150000 miles or 10 years.
Old Aug 2, 2023 | 12:12 PM
lexsc4's Avatar
lexsc4
GOOD LUCK!
I grow up in the wine country. Redding is not bad in terms of cost of living.
Been living in the heart of Silicon Valley for the last 30 years......we grow money on trees here. : )
OK. I will just have him do the brake fluid. Thx. the ES only has 39K miles on her anyway.
Old Aug 6, 2023 | 11:24 PM
john2101's Avatar
john2101
Definitely replace the coolant. At 6 yrs old, it had plenty of contact with the metal in your cooling system, giving it plenty of time to oxidize and using up the anti-corrosion additives. Also it is contaminated with dirt/dust and rubber particles from contact with hoses and seals.
It's a cheap insurance to replace it. I did on my 2018 with 26 K miles.
I would recommend replacing the cap also.
The brake fluid does need to be replaced too. The entire system doesn't hold very much, probably half a quart, so one quart should be plenty to refresh the fluid.
Good luck!
Old Aug 6, 2023 | 11:28 PM
lexsc4's Avatar
lexsc4
Good luck!
appreciate the advice. I was thinking the same on the coolant. Yeah, $75 labor plus 3 gallons of coolant is cheap insurance for sure.
Old Aug 7, 2023 | 12:08 AM
Ramziqadan's Avatar
Ramziqadan
10th Gear
brother waste of money
Brake should be bleeded every 6 to 7 years as per lexus manual and the coolant every 160K Mile
check your car manual , as yesterday i was checking the same question
Old Aug 7, 2023 | 05:00 PM
NdYAG's Avatar
NdYAG
I wonder what manual have YOU used to pull out those numbers...
Old Aug 7, 2023 | 10:33 PM
Ramziqadan's Avatar
Ramziqadan
10th Gear
don't wonder my dear
please check the maintenance manual for Lexus and you can see
it will have checklist for every 5K Mile maintenance till almost 200K Miles !
Old Aug 8, 2023 | 03:56 AM
NdYAG's Avatar
NdYAG
So,,, would you please show (picture or a link) a lexus manual where it calls for coolant change at 160k Miles?
Old Aug 8, 2023 | 05:04 AM
Ramziqadan's Avatar
Ramziqadan
10th Gear
here you go
https://carmanuals2.com/lexus/es300h...20022/page-69/
Old Aug 8, 2023 | 06:09 AM
autotech13's Avatar
autotech13
enough said!
