How to reset tail light failure?
Old Dec 9, 2021 | 02:12 PM
babyduke's Avatar
babyduke
Default How to reset tail light failure?
Tail light failure light lit up. Bulb was burnt out so I replaced it. Shop guy told me to use bulb 921 and it worked but the warning light is still on. All other lights work. I tested all of them while someone sat in the driver's seat.
Can someone please help? Thank you!
Old Dec 9, 2021 | 06:42 PM
tolian21's Avatar
tolian21
Check manual to confirm this is indeed correct bulb, maybe he sold you wrong bulb.
If its still an issue, I would try disconnecting car battery. If nothing help, Id think there is electrical issue somewhere…
Old Dec 10, 2021 | 09:07 AM
Clutchless's Avatar
Clutchless
You have the wrong bulb.
The best way to be sure you have the right bulb is to remove the same bulb from the other tail light and take it to an auto parts store to match it up.
The bulb numbers used in the Lexus owners manual are often not the bulb ID numbers you can find in an auto parts store. You need to cross-reference the bulb numbers.
nateses300
Jul 13, 2015 07:15 AM
kmengvang
Jan 11, 2014 07:16 PM
G_ride
May 10, 2010 08:45 PM
mike.gani
Lighting
Aug 26, 2007 04:25 PM
BlackRX
RX - 1st Gen (1999-2003)
Jan 10, 2006 12:30 PM
