EFI fuse blowing & VSC light on
Old Jan 22, 2021 | 04:11 PM
Xtreme1's Avatar
Xtreme1
Default EFI fuse blowing & VSC light on
Trying to help a friend with his 2008 ES350, car has 160K miles.
It just shut down out of the blue while driving. Check VSC light was on and I found the EFI fuse was blown. Replaced it and it blew again.
He took it to a local shop and they said the transmission is bad because when they unplugged the harness, the car will start. That still sounds like an electrical short to me, not a bad transmission.
He’s getting the car back Monday, I was just looking for suggestions on what to check. I plan on checking O2 sensors first but was hoping someone may have had a similar issue.
Old Jan 23, 2021 | 06:00 PM
Wilson2000's Avatar
Wilson2000
First use an OBDII reader to check for codes. Test the EFI relay. I don't have wiring diagrams for this vehicle, so it is hard to give specific advice. You may have a wiring short, or maybe the relay has an internal short. The good news is that you have some clues, like the blown fuse. Quiz the owner about any recent work done or anything out of the ordinary of late. It's not common to have issues "out of the blue," but it happens! Good luck.
Old Jan 23, 2021 | 06:32 PM
nevernu's Avatar
nevernu
here's the diagram if that's any help
File Type: pdf
Old Jan 24, 2021 | 08:11 AM
Xtreme1's Avatar
Xtreme1
The shop should have the codes and may have checked a few things already, I’ll find out tomorrow. I just find it odd that unplugging the t/m harness solves the fuse issue and allows the car to start. Anything sensors in particular to check on the t/m? I’ve seen people mention the harness in the driver’s wheel well getting damaged
Old Jan 24, 2021 | 01:39 PM
Wilson2000's Avatar
Wilson2000
Thanks, this diagram is partially helpful, but the wiring diagrams shop manual is called for.
The first thing I would be looking for is circuits common to both the EFI fuse and the wiring harness, that when disconnected, prevents the fuse from blowing. Visually inspecting the wiring harness downstream from the disconnect is called for. Each component downstream needs to be tested/inspected as well.
SnoViking
GX - 2nd Gen (2010-2023)
30
Apr 12, 2021 12:24 PM
Vols4life
GX - 1st Gen (2003-2009)
Nov 14, 2017 10:03 PM
gxman1
Jun 27, 2014 07:53 AM
350stew
Oct 23, 2013 04:57 PM
Patsum
Oct 10, 2013 10:06 PM
