ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Tweeter Speaker wires. (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/954622-tweeter-speaker-wires.html)
Zaavan Oct 12, 2020 11:24 AM
Hey guys, I was trying to figure which color for the speaker wires on the tweeters is positive and negative. Is the green wire positive and black one negative. Or the other way around?
I wanted to know because on the new tweeter I got, the positive is ornage and negative is black. Orange is left and black right. But the stock harness has black on left and green on right.
https://cimg7.ibsrv.net/gimg/www.clu...6a4d78a147.jpg
nevernu Oct 12, 2020 04:18 PM
1 Attachment(s)
this should tell you
SunglassesGuy Oct 13, 2020 09:31 AM
Did you figure it out? Here is the old battery test method.
https://www.lifewire.com/quickly-tes...ctions-3135135
SunglassesGuy Oct 13, 2020 09:36 AM
orange is positive. if you look close on the speaker, you can see a + sign
check the speaker you are replacing for similar markings, otherwise do the battery test if the colors in the upload don't match
Zaavan Oct 13, 2020 05:00 PM
Yea I figured it out. Black went with black and the orange connected to the green. The speakers are really nice, I know you got the same ones for your es. I did these for my left and right. I want to get a single one for the center but my ml is working fine right now.
SunglassesGuy Oct 14, 2020 09:13 AM
The are not a direct fit for the center. holes are about 1/4" too short, would need to add something to make it mount securely.
Did they drop right in for your dash left and right positions?
Zaavan Oct 14, 2020 09:25 AM
Believe it or not, they also were not a direct fit with the left and right either. I just put the screw down and held it tight against the mount. I also had to bend the edges to make it fit in the car itself.
