dark liquid
Old Jul 31, 2020 | 07:26 PM
Long3791's Avatar
Long3791
Default dark liquid
Ive known that there was something leaking under my es350 for a while now and I’ve finally had time to investigate. I took a look under my car and seem to have found a trace of where the leak drips from, but I can’t seem to identify what the dark substance on the PS pump is. I’m assuming that it’s either grease leaking from the cv axle or an oil leak. What’s your pick?
underneath of passenger side
Old Aug 1, 2020 | 12:19 AM
ESh's Avatar
ESh
CV axle grease.
Old Aug 2, 2020 | 12:20 AM
danielnas's Avatar
danielnas
it looks like your power steering pump is leaking. you may need to change it. if the liquid is dripping it's less likely to be grease.
Old Aug 2, 2020 | 08:39 AM
Hayk's Avatar
Hayk
You need look further. Spray some brake cleaner in the area and wipe off the mess, then check again if you can.
Old Aug 2, 2020 | 08:50 AM
ESh's Avatar
ESh
That is not power steering fluid.
The CV axle joint has really thin grease inside.
Old Aug 3, 2020 | 10:04 PM
Wilson2000's Avatar
Wilson2000
It looks reddish, like power steering fluid. I agree with cleaning it with a degreaser, driving it for a day, and then inspecting it again.
It's fairly easy to identify a CV boot leak as it flings the grease in a radial pattern all over the surrounding components.
Neelapala
13
Mar 7, 2022 06:56 PM
phphung
May 7, 2017 03:41 PM
Hammer28
GX - 1st Gen (2003-2009)
Mar 23, 2013 07:15 AM
VM 2
Apr 22, 2007 10:20 AM
