Headlight bulb replacement
I have been struggling with replacement of passenger side D4S headlight bulb. It’s impossible for me to attach bulb with the spring wire mount which appears to have been bent out of shape. The small ears that the spring wire clips to also appear damaged. Does anyone know where I can locate a replacement spring assembly or even a photo of what the correct shape of the spring mount would be. Any help would be greatly appreciated. Mike |
https://www.clublexus.com/forums/es-...problem-3.html see post 38. also in the same thread see dryfus excellent how to replace instructions
Is the passenger side clip different from the driver side clip? I would think they'd be the same, although I never had the notion to check.
Thanks nevernu and mkubo! |
