A/c on 2010 es350
A/c on driver’s side blows much warmer than on passenger side even though they are set at the same temp. Mechanic has added more refrigerant with dye twice and cannot see a leak in the system. This works for a few weeks and then the problem returns. Any thoughts on what it could be?
ah I had exact same problem a few years ago, my problem was had leak on vapor coil(located under the dashboard right beside the firewall). when refrigerant is low it doesn't fill the coil all the way that's why it only cool half way. when you recharge the AC it fills the coil all the way but if you have leak it get lower and doesn't fill the coil as suppose to. dealer asked $4200 for repair but it only cost me $180 for parts and it is not a easy DIY for sure. I hope you have leak other than coil where it's easy repair and cheaper repair good luck.
johnsnyder
Aug 14, 2017 09:23 AM
