Just bought a 2010 What do I need to check??
I just bought a used 2010 ES350 with 72000 miles. I had the transmission flushed and oil changed. Need new tires soon -thinking of Pirelli Cinturator P7 All Season tires over Michelin Premier A/S tires. Comments please. What else do I need to check or look out for? Thanks from geoleo
Flush the PS and brake fluid and you're good until 100K when it'll be time to get new plugs and coolant. I would check the brakes to make sure they have enough material; I would change them if they have less than 5mm.
Definitely for the PS - should have been done by 50-60K. If you switch to full synthetic, you may be able to stretch it a bit more. Brake fluid change varies more because of drivers' braking habits and environment.
Both fluids should be clear in OEM form. The PS replacement is Dexron III, a red ATF that is very expensive in clear form. I use Walmart's SuperTech at $12 a gallon. 2 Qts is enough to flush out the old stuff.
Look up youtube videos by Scotty Kilmer and Chris Fix.
Ssd108
Hybrid Technology
04-01-18 09:08 AM
YankinDeez
RX - 3rd Gen (2010-2015)
09-18-17 11:34 AM
