ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2011 ES350 with 51K - Rough idle while in R or D
Old 02-12-18, 09:22 PM
  #31
oldgrump
oldgrump's Avatar
To the original poster.......are you sure nothing was done to this car between the test drive at the dealer and the idle issue beginning? Any "tinkering" at all? As long as the Check Engine light does not illuminate while driving (or it dies on you) just drive the car for several hundred miles. Do NOT disconnect the battery again.......do NOT clean the Throttle Body again.......do not clean the MAF again. Let us know how it goes.
Old 02-12-18, 10:00 PM
  #32
dmullen137
dmullen137's Avatar
I did nothing to it other than put some FI cleaner in the tank and fill it up with 91. The throttle body had no record of having been cleaned -- so I cleaned it. The original owner was an 80 year old man, so I reset the ECU to forget about his driving habits. But, other than that, no, nothing has been done. Thanks for your suggestion -- that's exactly what I plan on doing
ESh (02-13-18)
Old 02-13-18, 01:33 AM
  #33
ESh
ESh's Avatar
Originally Posted by dmullen137
Absolutely. Sorry for the delay. I have attached a .pdf that has everything. Thanks again for everybody's input! Now back to driving the damn thing rather than worrying if something's wrong with her!
So the idle is good in neutral but it goes low in gear and the knock is 18,5 a it should be 21.
The alternator is 13,3 and that’s too low in my opinion.
Would you consider manually adjusting the throttle a bit?
Old 02-15-18, 05:54 PM
  #34
dmullen137
dmullen137's Avatar
I guess so, but you're having the same problem, right? You've replaced everything except the whole car lol. It concerns me because when I turn on my AC, the idle is well above 600, and the roughness is still there when it's in gear. Plus, the fact that the roughness only exists when the powertrain is engaged, I think it's something more than just a low idle. Could it be an axle? I saw mention of a water pump somewhere? The dealership knew that it was driving me crazy, and knew I'd spend any reasonable amount of money to fix it - and the fact that they came up empty-handed concerns me, to be honest. Even the motor mounts were fine...
Is there any other thing I could be missing? I had a friend get in and he noticed it right away. It's terrible. It's seriously like a Ford freaking Pinto and it sucks mega.
Old 02-15-18, 11:18 PM
  #35
oldgrump
oldgrump's Avatar
Firstly, if the engine is running and in gear but the car is not moving and you have the vibration, it's not a drive axle issue. What's missing here.......the car had only 51k on it when the OP bought it after a test drive where according to the OP it had no issues. Shortly afterwards the low idle and vibration issues started.
Where are you guys getting the idea to "clean" the TB, and the MAF?? Generally not recommended. This is now the fourth auto forum that I've participated in and in every forum where the cars have had electronic (fly by wire) TBs, and Mass Air Flow sensors, a fairly common complaint has been about performance issues immediately after the "cleaning" of one/both of these components with various spray/wet cleaners. Excess fluid can migrate from the throttle bore into the motor/electrical section of the TB. The other issue has been people manually attempting to open (forcibly) the throttle plate during the cleaning, which can damage the TB. If you insist on cleaning the TB, to open the throttle the Ignition is put in the "On mode" (engine not running) and the throttle pedal is used to open the throttle. MAFs can be damaged as well because the actual sensor wire (or film) is pretty delicate and should not be touched, or "blasted" with spray. Also, the Ignition must be OFF so there is no power to the MAF when "cleaning" the MAF with any fluids.
Basically.......with these cars, if the engine has no performance issues then cleaning the TB and MAF accomplishes nothing. With a properly installed OEM engine air filter the MAF should be subjected to very little contamination. The intake duct downstream of the crankcase vent tube connector, and the TB bore/throttle plate may have a visible film of oil but normally it should not cause a problem. If there is "excessive" oil in the intake it can be because the driver has a lead foot a lot of the time, or the PCV valve could be the cause.
With the cleaning of the TB and MAF obviously the intake ducting was disturbed.......are you sure that the duct is properly reinstalled and the clamps are snug? Are you absolutely sure that there are no vacuum leaks (no whistling noises that decrease with opening of the throttle)?. Can we assume the intake air cleaner is reasonably clean?
With the two cars above and because of the description of the low idle, and with what sounds like what could be a "miss", I'm wondering (even with no mention of the Check Engine Light ever being illuminated and with no related codes) could this be an ignition coil (or spark plug?) issue?
Old 02-16-18, 03:36 AM
  #36
ESh
ESh's Avatar
With the AC on mine works fine, and it also works OK if I slightly press the gas pedal. It works like a charm when the rpm is a little bit over 600 mark.
So, I think turning the glued screw a bit would make things better.
Old 02-16-18, 06:42 AM
  #37
jagtoes
jagtoes's Avatar
I'm with you here. Good summary .
Old 02-16-18, 10:53 AM
  #38
Clutchless
Clutchless's Avatar
Received 1,092 Likes on 932 Posts
Is there a sensor to increase idle when the transmission is placed into gear? If so, is it external to the transmission such that it could be tested and maybe replaced?
Old 02-16-18, 11:51 AM
  #39
ESh
ESh's Avatar
It should increase the idle like it increases when turn the steering wheel or when you turn the ac compressor on, but it’s not happening for some reason, and I think there’s no sensor for it.
dmullen137 (02-18-18)
Old 02-16-18, 04:22 PM
  #40
jagtoes
jagtoes's Avatar
I just did a quick check today when I had my 2010 out. At idle in park it is 650 rpm. When I move the selector to drive with my foot on the brake the idle drops to 605 rpm. Also my AUTO heat/AC system is always on. Readings were taken using my Torque Pro app from the OBDII port. This is ECM information. Oh water temp is at 197* F
Old 02-17-18, 12:31 AM
  #41
ESh
ESh's Avatar
Any vibrations?
Old 02-17-18, 04:30 AM
  #42
jagtoes
jagtoes's Avatar
Any vibrations?
No , none. Have 52K miles on it and don't remember if the idle has ever changed from day one. Also never had any reason to clean the TB which isn't necessary.
Old 02-17-18, 04:59 AM
  #43
ESh
ESh's Avatar
I mean, when I say “any vibrations”, can you feel the engine running on the steering wheel?
Old 02-17-18, 06:00 AM
  #44
jagtoes
jagtoes's Avatar
If I squeeze it yes a little but nothing that would be noticeable . I don't think it feels any different than any other car I own except my 2016 chevy PU. The 5.3 V8 is not a smooth idling engine
Old 05-06-18, 09:30 AM
  #45
munkjeep
8th Gear
munkjeep's Avatar
I took my 09 ES350 to the dealer right before 50,000 miles for a rough idle, the service writer said all ES350 do that, nothing wrong with it. A year later I replace all the Diamond Coils with Denso coils packs and the rough idle all but went away. I am thinking the Diamond coil packs was the issue >
Quick Reply: 2011 ES350 with 51K - Rough idle while in R or D
