Catalytic Converter
Catalytic Converter
my car es 350 2007 showing hazard light and check VSC. from computerized check i found catalytic converter b1 b2 low efficiency. i put new sensor as well. but still fault is there. is any cheap way to clear this fault
Great Deal Guru
http://www.ebay.com/itm/02-OXYGEN-SE...lUxb5w&vxp=mtr
Super Moderator
If you successfully fixed the problem, the light should go out by itself in a few drive cycles. You can also reset it immediately with a OBD2 code scanner or by disconnecting the battery for a few minutes.
Not sure about the ES350, but on the IS350 the P0420/P0430 low catalyst efficiency codes are usually caused by an exhaust leak in the Y-pipe under the heat shield.
