No premium gas available since Harvey
I can't find any premium gas since Hurricane Harvey hit. Will it hurt if I use regular unleaded in my Lexus ES? I have always used premium.
hisstojay (10-20-17)
Out of Warranty
Practically all cars and trucks that use gasoline run just fine on "regular", with the exception of a few high-performance cars and exotics that require premium fuel. Early Lexus cars were optimized for premium, but could quickly adjust their ignition timing to accept regular. The only difference was that on application of wide-open-throttle, the engine might balk for an instant as the knock sensors detected pre-ignition and quickly retarded the spark. This took about one or two revolutions of the crankshaft, so it was undetectable to the average driver. As far as any damage to the engine is concerned, just use top-tier brands with good detergent additives (or add your own, like a splash of Techron to your tank).
Gasoline is essentially a shared commodity, often stored in common containers until it is purchased by a major retailer. After that, the retailer treats the gas with a specific additive, thereby giving the fuel its brand identity. But are these additives just a dosage of marketing hype?
Top Tier gasoline was developed in 2004 to go beyond the minimum standard for detergent additives to better protect increasingly sophisticated engines from carbon buildup and deposits on the intake valves—which can result in a rough idle, acceleration hesitation, knocking/pinging, and reduced fuel economy.
Over the past 20 years, engines have become far more precise, operating under tighter tolerances and at higher compression ratios, while targeting cleaner emissions and improved fuel economy. To achieve these goals, eight automakers—Audi, BMW, Fiat Chrysler Automobiles, General Motors, Honda, Mercedes-Benz, Toyota, and Volkswagen—have united in support of Top Tier gas, specifically recommending it to their owners with the goal of preserving their engines’ original performance and emissions over time.
Top Tier retailers include 76, Aloha Petroleum, Amoco, ARCO, Beacon, BP, Break Time, Cenex, Chevron, CITGO, Conoco, Co-op, Costco, CountryMark, Diamond Shamrock, Entec, Esso, Express, Exxon, Holiday, Kwik Star Stores, Kwik Trip, Mahalo, MFA, Mobil, Ohana Fuels, Petro-Canada, Phillips 66, PUMA, QT, Quik Trip, Road Ranger, Shamrock, Shell / Shell V-Power, Sinclair Standard, SuperAmerica, SuperFuels, Tempo, Texaco, Tri-Par, and Valero.
- Consumer Reports, "Study Shows Top Tier Gasoline Worth the Extra Price"
i used regular in my 2007 all the time and our regular grates in the Mountian are lower than the southern fuel grades and i have no problem with using that in my car i use 87 mostly once every 10000 miles i will up with a full tank of premium fuel and chevron techron fuel cleaning aditive
petek22
03-11-24 09:44 PM
lilkyo410
09-28-14 06:03 PM
