2007 ES 350 Axle issues
Old Jan 28, 2020 | 04:59 PM
  #31
bucfan22's Avatar
bucfan22
yes, disc grinder, or jig saw with metal cutting blades. whatever you need to cut the thick solid axle. Key is to cut it real close to both side of the carrier so that once cut, you can see and remove the hidden screw. Once done cutting, everything else is easy. it sounds difficult only because we don't have much space when we get under there with jack stands.
Good luck
Old Jan 28, 2020 | 05:02 PM
  #32
Chris03218's Avatar
Chris03218
Good luck
Good to know, I would've had no idea there is a hidden screen
  #33
Chris03218's Avatar
Chris03218
Good luck
Smalach
Nov 4, 2018 03:37 PM
wayman28
May 2, 2015 07:39 AM
Tact
39
May 29, 2012 12:04 PM
lexus!!!!!
16
Aug 31, 2009 06:55 PM
