Rear Defroster Not Working
Hi
I have a 2010 ES 350 I purchased used a while back. This morning I had left the car out (ungaraged) for the first time. The windows were wet with dew, so I turned on the rear defroster. I drove for a good while, and never did see the moisture begin to disapate at the wires on the grid. The side mirrors did seem to be drying after a short time. The switch on the dash did light when I pressed it. It is my understanding that the mirrors and rear defroster are powered by the same fuse. I suspect that a relay may be in the circuit in addition to the fuse. Since none of the lines in the grid seem to be heating, I don't suspect a break in the grid. Has anyone had this problem and corrected it, or have information on the location of the relay. Any information would be much appreciated!!
Thanks,
Alan
Thanks,
Alan
Gdelossa (03-15-18)
Thanks nevernu,
I located the fuse and relay in the fuse panel under the hood. The fuse is actually enclosed in an assembly with several other fuses that I was unsure of how to remove, but the elements were somewhat visible from the side. I pulled the relay, and tested that I had 12v on one of the heavy contacts, and felt that the fuse was probably good. With this all appearing good I turned the rear defogger on and took my tester to the actual window grid. I grounded the tester on the rear door latch and found that I actually did have voltage on the grid on several lines.
Long story short, I was apparently not patient enough. The rear defogger on my Acura TL, and Odyssey just seem to work more quickly. I guess I'll be able to give it a real test when the snow comes. Thanks again, I really appreciated your help.
