ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
08' ES350 Moonroof / Sunroof Rattle
Old 09-02-16, 11:02 AM
TheCraiger
TheCraiger's Avatar
Default 08' ES350 Moonroof / Sunroof Rattle
I have searched and searched but cannot find a solution. I just inherited a 2008 ES350 with 52k on it and the sunroof rattles only when open from bhind the drivers side head area. When driving, I can get it to stop if I push up or pull down on it a little bit, but like I said...it only happens when in the full open position. Has anyone encountered this? Any fixes? Thank you for any informaiton.
Craig
Old 05-29-17, 12:05 PM
DIYDaisy
DIYDaisy's Avatar
Having the same problem Craig.
Found a post on 4th gen ES350 maybe you can locate it and see if the issue is solved there.
https://www.clublexus.com/forums/gs-...e-culprit.html
Old 05-30-17, 10:48 AM
Blueshark
Blueshark's Avatar
Speaking of the panoramic roof, Yes, i have it too. On mine, it is the wind deflector, i've tested it by holding the deflector while on bumps and yes, it does stop it. The spring arms seems to be weaken over time.
Lew270
11-15-15 11:56 PM
S54toIS350
03-19-15 11:21 PM
lomarica
08-19-10 05:49 AM
beercity
10-26-08 08:48 AM
Booyah
10-01-07 07:44 AM
Quick Reply: 08' ES350 Moonroof / Sunroof Rattle
