ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
synthetic oil or not
Old 10-07-10, 12:54 PM
safford197
safford197's Avatar
Originally Posted by Lust4Lexus
215 dollars is an absolutely criminal amount of money to charge for an oil change and rotation, even if it is synthetic.
I'm guessing $215 is for conventional oil. I believe back in early 2007, when I had my last stealer ship oil change the retail price was $175, but that was 3.5 years ago and it was for conventional oil.
Old 10-07-10, 01:22 PM
LexBob2
LexBob2's Avatar
The last time I checked, the dealership near me chared $88 for oil change (dino) and rotation. Still high, but not $215!
Old 10-07-10, 06:30 PM
WNCcruiser
WNCcruiser's Avatar
I paid $97 for oil change (Mobil One Synthetic) and tire rotation.
Old 10-08-10, 04:10 PM
JRey350hou
JRey350hou's Avatar
anyone. excuse for my ignorance but am I correct in saying that Mobil One is only Synthetic oil . I went by large Toyota dealership here in Houston area to see what chg would be for oil change ( have 11k miles....had 5k done free of chg ) and he said 29.99 for standard haviline oil change. I asked about upgrade and he said it would be mobil one would be $ 72.00. Not sure what Lexus will chg but for synthetic comparison I'm sure over 100.00.....opinions are welcome on what would be best...want to get done Monday. And know i dont do it myself....neighbors would probably call Homeowners assoc on me....pretty strict with things. Thanks guys !
Old 10-08-10, 05:34 PM
LexBob2
LexBob2's Avatar
Yes Mobil 1 is synthetic. $72.00 sounds like a good price. You are correct, it would be +/- $100 at a Lexus dealership. The $29.99 for Havoline isn't bad either...
Old 10-08-10, 07:00 PM
jagtoes
jagtoes's Avatar
Look at it this way. Most synt. oils cost $8 a qt. So the ES takes 6.5 qts or you would have to buy 7 qts. So that's $56 and the filter cost $12-$15 . Now you are at lets say $70 . It takes the tech 1/2 hr to do the job so I suspect they have a standard rate for oil changes instead of the $150/hr rate. So I would suspect Lexus to charge around $95 for an oil change. That's my guess.
Old 10-09-10, 03:01 PM
JRey350hou
JRey350hou's Avatar
lexbob & jag....thks for the advise . I'm going to go with Mobil one...will call Lexus dealer just to see what they will chg for synthetic oil. I didnt even know how much qrt of synthetic oil cost so after getting the info it seems to be very fair price. thks again !
Old 10-09-10, 03:37 PM
jkutti2000
jkutti2000's Avatar
dallas .. park lexus charged 70 for std oil change
Old 10-09-10, 04:09 PM
Koz
Koz's Avatar
I post this every once and a while. It's just some facts about the differences between dino and synthetic.
Even though petroleum refining is an advanced science, small amounts of contaminants, such as sulfur and reactive hydrocarbons cannot be completely removed from petroleum, and end up in motor oil base stocks. Synthetics base stock are designed in a lab and therefore do not contain these contaminants. So right from the start petroleum oil is contaminated.
Petroleum oil molecules are of varying sizes. So, as a petroleum oil heats up, the smaller molecules begin to burn off. Deposits and sludge are left behind to coat the inside of your engine. In addition, as smaller particles burn off, the larger, heavier molecules are all that is left to protect the engine. Unfortunately, these larger particles do not flow nearly as well and tend to blanket the components of your engine which only exacerbates the heat problem as friction builds-up. Synthetic oils, on the other hand, because they are not purified, but rather designed within a lab for lubrication purposes, are comprised of molecules of uniform size and shape. Therefore, even if a synthetic oil does burn a little, the remaining oil has the same chemical characteristics that it had before the burn off. There are no smaller molecules to burn-off and no heavier molecules to leave behind. OK, I said I would try to keep it short, bottomline is synthetics contain almost no contaminants compared to petroleum oils since they are not a refined product. As a result, if oil burn-off does occur, there are few, if any, contaminants left behind to leave sludge and deposits on engine surfaces.
Petroleum oils also contain paraffins (wax), they tend to thicken up considerably in cold temperatures. Additives are used to help keep the oil from thickening too much due to these waxy contaminants. Synthetic oils, on the other hand, contain no paraffins. Therefore, they need no additive to help with cold temperature operation. Moreover, even without the additives, synthetics flow at far lower temperatures than petroleum oils. Remember additives cause contamination!
Since synthetics contain no additives to aid with cold temperature flow, synthetics maintain their cold temperature flow characteristics for a long period of time. Additive depletion is not a factor in the cold temperature flow of synthetic oils. Synthetics do not thicken due to burn-off. So, this is not a factor in cold temperature flow either. Of course, the obvious result is that you don't need to change synthetic oil as often to regain adequate cold temperature flow.
Water causes acids to be created within the oil and corrosion will begin within your engine. So, there are additives in the oil which are designed to combat these acids. Synthetics contain higher quality and a higher quantity of these additives in order to properly neutralize these acids for a longer period of time. These additives do deplete over time, but it takes longer with synthetic oils than with petroleum oils.
Here's a couple important facts; Additives are also used to keep oil contamination in check and to keep it from damaging your engine. These additives keep potentially wear causing contaminants suspended and contained in your oil so they don't cause excessive wear or deposit build-up within your engine before your filter can remove them. Synthetics have higher additive treat rates than petroleum oils (in addition to using higher quality, more expensive, additives), so they can perform this contaminant control function for a much longer period of time than a petroleum oil can.
To control acids the Total Base Number (TBN) describes the acid neutralization ability of an oil, with higher TBN oils providing longer lasting acid neutralization. Synthetics nearly always have higher TBN values than petroleum oils do. The result: longer and better acid neutralization capability allowing for extended drain use.
Koz
bigblack06
06-01-12 12:08 PM
Zinda
10-05-10 01:27 PM
GSLEX
RX - 3rd Gen (2010-2015)
19
02-06-10 08:54 AM
JDKane527
Performance
64
07-21-09 09:58 AM
martialart
Maintenance
21
10-30-03 06:47 PM
Quick Reply: synthetic oil or not
