Why does it chime in this scenario?
Shift into park, keep engine running, open driver's door, keep it open, turn off engine. The reminder chime starts to sound. Why does it chime? I thought maybe as a reminder to take the SmartAccess key but if you shut the car off before opening the door the chime does not occur.
I can't really answer your question but can confirm the my car does the same thing. I haven't really paid much attention to it but because if often happens when I pull into my garage I have have wondered if it isn't related to the fact the the headlights are on.
Dave Mac |
When the sunroof is left open, it chimes and gives you the message on the dash that the sunroof is open. For your example, it chimes with no message. And, the lights can be off too.
Mine does it too. I have always wondered myself, but placed it on the "not concerned" list. However, if anyone else knows why...I'd love to know. :uh: |
The owner's manual does list this scenario as expected behavior. There is an "Electronic Key Alarm" section that has a chart and lists all the scenarios where the chime will be triggered and this is one of them but there is no explanation as to WHY the chime sounds in this situation.
Alarm: Interior alarm pings continuously Situation: Turned the “ENGINE START STOP” switch to ACCESSORY mode while the driver's door is open (Opened the driver's door when the “ENGINE START STOP” switch is in ACCESSORY mode.) Correction Procedure: Turn the “ENGINE START STOP” switch OFF and close the driver's door. Situation: Turned the “ENGINE START STOP” switch OFF while the driver's door is open Correction Procedure: Close the driver's door. |
Try turning off the car first then opening the door.
Originally Posted by iKenn
(Post 3760618)
IIRC, it chimes because the steering wheel is not locked. Just press and release the black rubber door switch by hand, and the steering wheel will lock and the buzzer will cease. It's annoying and seems pointless to me.
Please elaberate on the black rubber door switch....thanks
Originally Posted by YotaCarFan
(Post 3796325)
It's certainly annoying. I've learned to turn the car off before opening the door.
Originally Posted by MD350
(Post 3796781)
| All times are GMT -7. The time now is 12:57 AM. |
