ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Replacement passenger side mirror cost, part# and difficulty on install? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/1038074-replacement-passenger-side-mirror-cost-part-and-difficulty-on-install.html)
thatcalifi Apr 6, 2025 10:14 AM
2012 ES 350 GS40VL
Color: C/TR: 1H9/LA00 I believe Mercury Grey Mica
The motor and bulb still work, I managed to crack the housing and the blinker cover, it also has a puddle lamp on it. Pics below. I'll give you a guess how I managed this 🤦
I've tried browsing the OEM site but it's not clear to me which is which. I think the part # is 87910-33881-C0 -- but I'm not sure and I don't know if the color will be same?
Thanks so much in advance
https://cimg6.ibsrv.net/gimg/www.clu...5d57df308c.jpg
https://cimg7.ibsrv.net/gimg/www.clu...e8d91c69a9.jpg
https://cimg8.ibsrv.net/gimg/www.clu...208dcd5109.jpg
https://cimg9.ibsrv.net/gimg/www.clu...3ae36b0a30.jpg
https://cimg2.ibsrv.net/gimg/www.clu...9601011234.jpg
Gugi53 Apr 6, 2025 11:35 AM
Originally Posted by thatcalifi (Post 11891787)
2012 ES 350 GS40VL
You have to go see the dealer for part, you have to give the Win # and year the vehicle. To change, you have to take the inside door cover off where is the connector, take three bolts of and change it. Easy to say when you know.
Here is how. Good luck.
thatcalifi Apr 6, 2025 01:41 PM
After some sleuthing I came to realize I just need to replace the outer shell. So I ended up getting the
8791A-53411-B2 COVER, OUTER MIRROR, RH
https://www.lexuspartsnow.com/parts/...-53411-b2.html
81730-53020LAMP ASSY, SIDE TURN
https://www.lexuspartsnow.com/parts/...730-53020.html
And apparently the mirror just pops off revealing screws that hold the assembly together and the rest comes off.
Gugi53 Apr 6, 2025 05:53 PM
Good luck.
thatcalifi Apr 6, 2025 06:33 PM
Originally Posted by Gugi53 (Post 11892053)
Good luck.
Thank you 😊
