Transmission Drain and Refill with filter change
Anyone here did drain and refill with filter change at high mileage? (Over 100k miles).
im not talking about full flush but drain and refill around 8 quart.
I have 132k on mine and never did any transmission fluid change.
Thinking about draining and dropping the pan and changing the filter and put back in what comes out.
This process it will drain out 7-8quart and total transmission holds around 21quarts so it’s like changing around 1/3rd oil which will refresh the old oil.
im a little paranoid but wondering anyone did it at this many miles (130k)?
https://at-manuals.com/manuals/lexus...y-instruction/
total system may be 8+ quarts , but drain and fill probably is 4 quart
This has been discussed a lot. See these older threads which also contain detailed instructions. There is a complicated procedure designed by Toyota (to annoy DIY folks) to get the fluid level adjusted correctly. It is explained in some of these links.
FYI the total fluid in the transmission is only about 7.3 quarts. Not 21 as you stated. Read the links below and learn about your transmission, which is the Aisen U660e model.
https://www.clublexus.com/forums/es-...ans-fluid.html
https://www.clublexus.com/forums/es-...with-pics.html
https://www.clublexus.com/forums/es-...000-miles.html
https://www.clublexus.com/forums/es-...uid-flush.html
https://www.clublexus.com/forums/es-...placement.html
MaxKechely
Jun 13, 2023 11:41 AM
CruiserRX
Oct 17, 2019 08:16 PM
USMCLexus
Jul 14, 2010 10:31 AM
