Tail Light Bulb Replacement
Old Feb 16, 2024 | 12:38 PM
ChristineR's Avatar
ChristineR
2nd gear
Default Tail Light Bulb Replacement
Hi all!
I have to take my car through inspection in a few weeks. Come to find out, one of my lights is out.
Can anybody help me figure out what size bulb I should be looking for to fit in this spot?
Any recommendations would be greatly appreciated! (LED would be preferred)
Old Feb 17, 2024 | 04:19 AM
sthpawil's Avatar
sthpawil
Are you referring to the white backup lights? You'll need an assistant to put the car in reverse to see if they are working.
If they need replacement, they are bulb # 921 (12.8V, 17.9W).
Also, did you check your brake lights, including the third brake light in the rear window? You'll need an assistant to press down on the brake pedal for you (or use something to hold the brake pedal down while you check the lights).
Old Feb 17, 2024 | 08:17 AM
spaceballs's Avatar
spaceballs
Originally Posted by sthpawil
Those are your backup lights. You'll need an assistant to put the car in reverse to see if they are working.
You can actually do it yourself, turn your car on (but not started, just the electricals on ACC), put on the parking brake, and put your car into R, it will cause the lights to light up, but your car is still being held in place by the parking brake and the engine is not running.
Yes it will incessantly beep at you for leaving it in R when exiting the vehicle but it will work.
Old Feb 17, 2024 | 12:26 PM
ESh's Avatar
ESh
Bulb 7443.
Old Feb 18, 2024 | 03:46 PM
sthpawil's Avatar
sthpawil
Figures... one of mine burnt out today (the bulb for the red lenses on the trunk lid). It is called the parking light, bulb #168.
Simply pull down on the black liner and two push clips will pop out. You will then have access to the bulb.
Parking light (red lenses on trunk lid), bulb #168
Bulb # 168
DAVEB1980
Jan 30, 2024 04:00 AM
Fpan87
RX - 3rd Gen (2010-2015)
Nov 3, 2023 11:03 PM
mijobo
RC - 1st Gen (2015-present)
Oct 22, 2021 06:17 PM
mate01
Jun 9, 2016 03:01 PM
nysupraman
Lighting
Aug 29, 2003 12:49 PM
