Transmission Flaring (slipping)
Old Nov 2, 2023 | 12:01 PM
ESh's Avatar
ESh
Originally Posted by dave5000
THank you! Do you mean a Chinese cable or an actual Mongoose? Thanks again!
The chinese clone. Works flawlessly.
Old Nov 2, 2023 | 01:00 PM
Jayden301's Avatar
Jayden301
5th Gear
Sounds fantastic! I will try it too later today and update here to let everyone know!
on my way this morning i did notice it flared once very lightly at cold start from 3-4. usually for my car the flares are intense and happen about 3 times before shifting smoothly again. so i did notice improvement although i am going to want to buy that mongoose cable from aliexpress, please point me in that direction if you end up finding it, thank you!
Old Jan 10, 2024 | 05:01 AM
Drcoffee's Avatar
Drcoffee
I have a twist on this topic. In both of our toyota siennas ‘08 & ‘14 had shifting issues. I decided to replace the tranny fluid thru the cooler line with 12 qts of toyota brand fluid. Knowing that ATF is a detergent and purging the old fluid and replacing it with new will clean the crud out of the tranny within a few hundred miles, I added an inline filter to the cooler line to capture the freed grit and grime. I used the Magnefine filter 3/8” size. And also added a trans cooler to keep the ATF from reaching 200*F. Since then the gear hunting at all speeds has resolved. Also if Im not mistaken you want to heat the tranny to 116*F to set the level. OP what did you use to read the the transmission temp?
Old Jan 10, 2024 | 05:06 AM
dave5000's Avatar
dave5000
10th Gear
Originally Posted by Drcoffee
I have a twist on this topic. In both of our toyota siennas ‘08 & ‘14 had shifting issues. I decided to replace the tranny fluid thru the cooler line with 12 qts of toyota brand fluid. Knowing that ATF is a detergent and purging the old fluid and replacing it with new will clean the crud out of the tranny within a few hundred miles, I added an inline filter to the cooler line. Its the Magnefine filter 3/8” size. And also added a trans cooler to keep the ATF from reaching 200*F. Since then the gear hunting at all speeds has resolved. Also if Im not mistaken you want to heat the tranny to 116*F to set the level. OP what did you use to read the the transmission temp?
I used a scan tool and a laser thermometer, for my car it is at 110°F. I also flushed using the cooler lines.
Btw, I haven't had the time to try to do the transmission update. I work a lot with my car. It has been 10k miles and it is not as bad as before but still does but a lot softer now. I still want to try the software update.
Old Apr 29, 2025 | 05:10 AM
dave5000's Avatar
dave5000
10th Gear
I work at a Toyota Dealership now and one the techs updated the TCM. Vehicle is a lot better now. Almost perfect. There is a TSB about replacing the valve body but it would be $1k plus. Since it is so much better now, it is not worth replacing it.
Old Nov 16, 2025 | 10:38 PM
Isaaces's Avatar
Isaaces
1st Gear
Default 2012 es350
Originally Posted by ESh
I wrote about this many times. I think the reset may help and may not. Maybe it is a good idea for you to purchase the Techtream and reset the tranny adaptations by yourself.
What kind of filter you used? OEM? It looks like you did not use OEM.
hey I have a question my 2012 es350 makes this noise it almost sounds like there’s a rock in my rockers it happens when I’m going slow then to a dead stop and when I lightly accelerate and sometimes on bumps
Old Nov 17, 2025 | 02:45 AM
ESh's Avatar
ESh
Very hard to answer you. Can you make a video?
mocanu
Sep 6, 2024 01:49 PM
mailmycop
Jul 3, 2024 06:27 PM
NewSlang
37
Sep 8, 2020 08:43 PM
Jolzer
Apr 2, 2014 02:45 PM
dunnojack
Mar 13, 2007 02:24 PM
